It is currently Sun May 31, 2026 3:10 am
PostPosted: Tue Jan 20, 2026 8:03 am
Last Name: Ensor
State: Missouri
For a low profile, full width heel... where would you put the neck side strap button?
I typically put them on the heel on the treble side when using a martin cone style heel. Don't like that option here. Too small. Thoughts?
http://elevatelutherie.com
These users thanked the author Chris Ensor for the post: Chris Pile (Tue Jan 20, 2026 11:46 am)
PostPosted: Tue Jan 20, 2026 8:27 am
I like t put a small reinforcement block glued to the neck block, and drill through the side above the heel kinda like a tele…
These users thanked the author meddlingfool for the post: Durero (Wed Jan 21, 2026 3:59 pm)
PostPosted: Tue Jan 20, 2026 10:21 am
City: U.P.
Beautiful looking guitar Chris!!
I've done the same thing Ed has and the customers liked it.
My neck block is probably larger than most so plenty of room to securely hold a neck strap button.
Brian R, Wood Mechanic
N8ZED
PostPosted: Tue Jan 20, 2026 10:25 am
Last Name: Ensor
State: Missouri
This one has structured sides but I may glue a little block on the inside just in case (should I go that route). Any other ideas?
PostPosted: Tue Jan 20, 2026 3:09 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I have put the strap button where Ed recommends on a few of my guitars. It's a good solution. Doc Watson thought so, too. I am more comfortable doing that when I can glue the internal block on during construction, rather than in a completed guitar. But you can do it after the fact without a problem.
For the heel in the photo, putting the strap button on the flat part, right at that middle maple line, would probably work fine. But beware of any internal hardware, obviously.
PostPosted: Fri Jan 23, 2026 10:26 pm
I put it on the side on my archtops using a reinforcement block inside.
PostPosted: Thu Jan 29, 2026 6:11 pm
Last Name: Ensor
State: Missouri
Yep. That'll do:
Thanks for the suggestions.
These users thanked the author Chris Ensor for the post (total 3): Durero (Fri Jan 30, 2026 2:05 pm) • Bryan Bear (Fri Jan 30, 2026 9:42 am) • SteveSmith (Thu Jan 29, 2026 8:24 pm)
PostPosted: Thu Jan 29, 2026 7:32 pm
Very nice!
PostPosted: Sat Jan 31, 2026 9:08 am
City: Lawrence
Zip/Postal Code: 66047
Bump
