It is currently Sun Aug 03, 2025 1:01 pm
PostPosted: Fri Oct 04, 2013 3:26 pm
City: Quakertown
State: Pa
I was doing some looking around on the net and came across this picture of a Kenneth Lawrence Explorer and was puzzled on how you would go about cutting this tennon. It looks like the fretboard extension is not wings and is cut into the neck blank. My best guess is that it is routed from the underside (bottom of the heel) so that the router bit curvature is between the tenon and the face that butts against the body. Any other guesses?
PostPosted: Fri Oct 04, 2013 5:53 pm
First name: Matt
Last Name: Cushman
City: Great Falls
State: MT
Zip/Postal Code: 59401
It could be routed as you suggest. If the builder had a mini milling machine that would get the job done quickly. I have made similar neck joints using my mini mill. It is one of my most favored power tools. There are probably many ways to do this, so the best way to find the answer is to ask the maker.
http://www.cushmanguitars.com/.
A man who carries a cat by the tail learns something he can learn in no other way.
Mark Twain
PostPosted: Sat Oct 05, 2013 2:09 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I'd say route from underneath like you suggest then chisel out the one inside corner that's rounded because of the router bit.
Kevin Looker
I'm not a luthier.
PostPosted: Sat Oct 05, 2013 3:53 pm
First name: duh
Last Name: Padma
The tenon was cut first, with any number of different saws...take your pick and then the extension was planted added on at about the 18~19...now that may just be a pencil mark, if so ...any one of the above answers would do it including a chisel.
blessings
duh?adma
