It is currently Sat Aug 02, 2025 4:43 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Gold Top help
PostPosted: Sun May 18, 2014 2:03 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Zip/Postal Code: 30308
Thanks Brian. Do you have a recommendation for a gun with a smaller needle? Can't spend a ton but I'm thinking maybe that will help. Just trying to do whatever I can to make the next one go smoothly. I don't know how many more attempts I have left in me.
"I'm not going to say that perfection has never been achieved. However, if it has, it probably went unnoticed due to it's lack of character."
PostPosted: Mon May 19, 2014 7:23 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Most of the cheap guns I see these days all seem to have tips in the 1.8mm range. I used HF guns for a long time but they now all seem to have that same tip size. Check maybe Northern Tool or even Grizzly. I would recommend a gravity fed design, especially for metallics.
Brian
PostPosted: Tue May 20, 2014 5:56 am
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Thanks Brian. I picked up a two gun set at Harbor freight yesterday for about 50 bucks. It has a small gun with a 1 mm tip and a larger gun with either a 1.4 or a 1.8 mm tip. Gravity feed design like you said. I immediately use the smaller one for touching up some black paint on a headstock and it worked quite well. I am still prepping the other body for the gold paint so we'll see how that works once I get to spraying it.
