It is currently Wed Aug 06, 2025 9:57 pm
 Post subject: My First Project
PostPosted: Thu Aug 25, 2011 3:05 pm
First name: Adam
Last Name: Salter
City: Cwmbran
State: Torfaen
Zip/Postal Code: NP44 1QL
Country: UK
Hi guys, Just signed up and i would really like some advice on building my 1st guitar. I have purchased some tools that i have been told are essential in this hobby and i have watched numerous videos on youtube. My first in what will probably be a long line of questions is the following. For the body of my guitar i will be lining 3 planks of mahogany or maple side by side and glueing, then holding together with clamps (But i dont know how long to di this for yet). My main question is what should i use as adhesive to hold these pieces of wood together?
 Post subject: Re: My First Project
PostPosted: Thu Aug 25, 2011 4:34 pm
First name: Brad
Last Name: Broomfield
City: Edmond
State: oklahoma
Zip/Postal Code: 73025
Country: United states
I use standard wood glue. there are many brands available but i like to use titebond. Holds well and dries fast. It has an open time of 5 min or so. This means you need to have it set the way you want it and in the clamps withing 5 min. Then i will let them stay in the clamps for at least 2 hours before i remove them, but if you dont need the clamps for a while i would leave them in the clamps overnight. Get your joints as tight as possible before you even put glue on the board. Clamps dont fix problems they wont pull a not so good joint together. I would even do some test runs before using glue, just to make sure you know how everything will work and there are no surprises. The better job you do gluing the boards together, the easier the next step will be. As always, attack everything with a get it right the first time attitude, and it will reduce the fixes you will need to do later.
PostPosted: Thu Aug 25, 2011 8:27 pm
First name: Mark
Last Name: Sorrentino
Elmers glue.
...No really, I'm serious. Just as good as Titebond, and much cheaper. Heck, you could probably find some lying around for free.
PostPosted: Thu Aug 25, 2011 11:40 pm
First name: Virgil
Last Name: Mandanici
State: FL
Welcome Adam and good luck on your new adventure - I just finished what you are just starting (First guitar, but don't do what I did, they will lock you up in an asylum!))- I used Titebond and it hasn't come apart yet - let it sit for 24 hours after gluing. Keep us posted and take as many pics as possible (Post them too!)
PostPosted: Fri Aug 26, 2011 11:56 am
First name: Adam
Last Name: Salter
City: Cwmbran
State: Torfaen
Country: UK
I will guys, Thanks for your help thus far.
PostPosted: Fri Aug 26, 2011 10:34 pm
First name: David
Last Name: Morris
City: McKinney
Personally, I'm a big fan of Titebond, but do make sure you guys Titebond I, or "Original." The waterproof stuff sounds better, but for guys like us, the red bottle's where it's at. Also, don't go to a woodworking specialty store. Get it at the big box retailer to save some money. For me, the confidence of a proven glue is worth an extra couple of dollars when you consider its importance to the build as compared to the percentage of cost you're going to spend in the long run.
Welcome to OLF!
David Morris
PostPosted: Sat Aug 27, 2011 12:48 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
There are many glues you could take to joint your blank: Titebond, White glue (the LMI one), Hot Hide Glue, Fish glue, Epoxy resin...
I think that the easiest to work with, for you, and the easiest to find is the Titebond. Take the Original one, red bottle.
Less glue is better (but spread it fast, 'cause you don't want to let it begin to dry before assembling the pieces. Try to do it under 2 minutes.)
Epoxy is more expensive and harder to find. It is very strong and stable, and you have at least 15 minutes to spread it before it begins to cure.
Chameleon wrote:
Elmers glue.
Disagree.
The choice of glue is something important. Each glue have pros and cons for different steps of the building.
For me, the elmer's don't fit anywhere, or maybe to stick a paper template on a MDF.
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sat Aug 27, 2011 12:54 am
First name: Virgil
State: FL
Ahhhhh, let the glue wars begin. Betcha this point has never been argued before beehive
PostPosted: Sat Aug 27, 2011 8:37 am
First name: Alex
Last Name: Takacs
State: Illinois
I also disagree with the idea that elmers glue is as good as titebond. I heard this rumor about elmers glue a while back, so out of curiosity I decided to run some tests. I glued two small blocks of wood together with titebond 2 and two small blocks with elmers glue. After 24 hours to dry I was able to pull the blocks glues with elmers glue apart with absolutely no effort. I couldnt pull aprt the titebond 1 blocks. I then tried to chisel the titebond blocks apart at the glue joint. The wood directly next to/around the joint broke before the glue. I used titebond 3 on all parts of my guitar except for the fretboard. To glue down the fretboard, I used titbond 1 so I could remove it with heat and steam in the future if necessary.
