It is currently Wed Aug 06, 2025 5:49 am
PostPosted: Sat Jul 28, 2012 11:55 am
First name: Alex
Last Name: Takacs
State: Illinois
The title says it all boys, I need to know what 5-way switch will work on an HSH pickup configuration like a Jem. Neck humbucker, Center single coil, and bridge humbucker. Thanks in advance -Alex
PostPosted: Sun Jul 29, 2012 12:36 pm
First name: Mark
Last Name: Sorrentino
You can use any of them, even cheap ones out of Squier Strats. Now if you were looking to do something fancy like have split coil or series parallel stuff, you may need a fancier switch or just more switches. But if your humbuckers are to be wired just as a regular humbucker in series, you can use the same stock diagram as a strat.
