It is currently Tue Aug 05, 2025 1:15 pm
PostPosted: Thu Jan 24, 2013 8:46 pm
First name: D
Last Name: S
Correction - "up" bow
I just received a 17" SM Martin-style truss rod.
The aluminum channel is not straight, but already has some up bow in it - maybe .03"-.05" at the center.
The nut is loose. Is this bow normal?
Should I try to straighten it before installation?
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Mar 04, 2013 2:00 pm
First name: David
Last Name: Lane
City: Corryton
State: Tennessee
Zip/Postal Code: 37721
Is this "up-bow" as defined with the open side of the channel being up? I've never had a problem with one of those, but try this. Put just a little bit of tension on that adjuster................does the bow disappear? If not, send it back ;)
"No trees were harmed in the creation of this message, however some electrons were temporarily inconvenienced."
PostPosted: Mon Mar 04, 2013 6:30 pm
First name: D
Last Name: S
Nope, it's the closed side of the channel that is bowed up (sorry if I mixed up the terms).
I installed it in a rather stiff neck and then levelled the fretboard. All seems fine.
Dan
wah
Wah-wah-wah-wah
Wah
