It is currently Sun Aug 03, 2025 1:00 pm
 Post subject: Neck angle problem!
PostPosted: Wed Sep 11, 2013 2:14 pm
First name: Dean
Last Name: Heard
City: Bournemouth
State: uk
Zip/Postal Code: BH1 4ED
Country: England
I have built the neck and made the Mortise and tenon joint. I have drilled the holes for the bolts and bolted the neck to the guitar, but the neck is sitting back to far! What can I do to change the angle without shorting the neck from the 12 fret position?
 Post subject: Re: Neck angle problem!
PostPosted: Wed Sep 11, 2013 2:21 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
It does not take much to change the angle a lot. If the angle is too steep and the heel cheeks are sitting nicely on the rims and the neck is flush with the top, you will have to change the angle of the cheeks taking a bit more off the fret board side of the heel cheeks. I can not imaging you are so far off that the 12th fret will be noticeably lower.
PostPosted: Wed Sep 11, 2013 2:31 pm
First name: duh
Last Name: Padma
Do the rest then...
Shift the fretboard towards the head stock too keep the 12th were needed.
or
reposition the saddle and live with the 12 slightly off...probably won't be all that much .
PostPosted: Wed Sep 18, 2013 1:19 am
First name: Alex
Last Name: Takacs
State: Illinois
Sandwich a wedge shaped shim between the fretboard and the neck
