It is currently Sun Aug 03, 2025 12:06 am
PostPosted: Sun Aug 10, 2014 11:12 am
First name: Mark
Last Name: Sweeney
City: South Ohio
State: Nova Scotia
Zip/Postal Code: B0W3E0
On my current build which is almost finished, I am making my wiring cavity covers magnetic, as opposed to screw in. so today, I inlaid my magnets on both the cover and the guitar, and I done gone f*d it up, lol. the magnets are pushing away from each other instead of attracting, and they are held in with super glue. is there a way to get these out of either the guitar or the cover without ruining them, or should I make another cover?I suppose I could try to drill them out, but I wondered if there might be a special trick for debonding the super glue and pop the magnets out? thanks
PostPosted: Sun Aug 10, 2014 5:17 pm
First name: Mark
Last Name: Sweeney
City: South Ohio
State: Nova Scotia
Drilled out and fixed. Quick and painless for anyone's future reference
PostPosted: Sun Aug 10, 2014 6:12 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I'm truly sorry about your mistake, but I don't think it'll take much to fix it. But this does raise a question for me: Apart from drilling out, would heat from a soldering iron applied right to the magnet make the glue release? I'm asking because I want to know. Is it practical to release super glue with heat applied in this fashion? I am certain someone out there has tried this. Please tell us about your results.
In the meantime, Mark, keep your chin up. I'll bet we get additional suggestions before morning....
If we don't, then you know they can be drilled out, and that's not the end of the world, either.
These users thanked the author cphanna for the post: pikolo (Sun Aug 10, 2014 7:15 pm)
PostPosted: Tue Aug 12, 2014 8:02 pm
First name: Isaac
Last Name: Im
City: Chatham
State: NJ
Zip/Postal Code: 07928
theoretically heat can debond any glue, but heat can damage the material that is glued.
Who cares about tone if you can look hardcore?
PostPosted: Wed Aug 13, 2014 11:46 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
The heat from a soldering gun will make CA let go, but heat will also de-magnetize.
I'm not sure if the order of magnitude of heat required to release CA would damage a magnet.
PostPosted: Fri Aug 15, 2014 6:44 pm
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
Try some Acetone, which is supposed to be a solvent for CA glue.
Nothing to loose!
PostPosted: Thu Sep 11, 2014 3:04 pm
Once you do get them out use a piece of steel (or a flat screw) for one side. Two magnets stuck together can be a bear to get apart.
