It is currently Thu Aug 13, 2026 6:59 pm
 Post subject: Finish repair help
PostPosted: Mon Jun 01, 2026 6:16 pm
Reworked a neck to change a locking nut to a regular bone nut. Owner knows that the finish won't match but I would like to get as close as possible. The color on the neck is semi-translucent with lacquer top coat. I have tried tints in shellac (an old go-to for me) and then decided to give the new GluBoost colors a try. Both are too translucent.
My shop compressor died so that complicates things.
Looking for some ideas to get a decent color match with something that is more opaque.
 Post subject: Re: Finish repair help
PostPosted: Mon Jun 01, 2026 7:59 pm
I would hit that with a mix of brown and yellow Keda dyes in water until I got the right amber, and then use TruOil as a finish.
These users thanked the author Chris Pile for the post: SteveSmith (Tue Jun 02, 2026 6:34 am)
PostPosted: Tue Jun 02, 2026 6:36 am
Thanks Chris, that’s similar to the way I learned to do sunbursts but for some reason had not occurred to me.
PostPosted: Tue Jun 02, 2026 10:15 am
Rock on with your bad self.
These users thanked the author Chris Pile for the post: SteveSmith (Tue Jun 02, 2026 12:32 pm)
PostPosted: Fri Jun 19, 2026 1:35 pm
Dye didn't work - it would have if the original finish was a dye/stain with a clear coat but this one had a clear sealer with a colored lacquer over the top. Result was a undyed ring around the repair probably from the sealer. Sorry I didn't get a photo.
Fortunately I got the compressor issue solved so I'll try the air brush. Did I mention I'm not the best at finish work ;)
PostPosted: Wed Jul 01, 2026 7:48 pm
Figured l would follow up on this neck rebuild to change from a locking nut to a bone nut. The woodwork was straightforward but I was having trouble matching the finish.
I decided to take the time to try out several finish repair techniques. I spent a lot of time with the GluBoost Master Tints, just couldn’t get a good match across the larger area. Then I tried the Keda water based dyes Chris recommended, that worked well for a color match but left a witness ring around the new wood. I expect the ring was where I sanded into the existing finish and there was a band of sealer as it faired from bare wood to the finish.
I used a fair amount of maple scrap-ha. I treated it as a learning experience and I’m sure the knowledge will be useful.
I was able to solve my compressor problem so for the next technique I ended up airbrushing with Transtint in shellac which worked well. I was happy with the color match. I followed up with 4 coats of lacquer, a very light level just to knock down any bumps and finally a light buffing.
I used the GluBoost Lac R Shot spray lacquer. I had wanted to try it. It worked really well and sprayed better than any rattle can I’ve used before.
These users thanked the author SteveSmith for the post (total 3): Kbore (Sat Jul 11, 2026 3:55 pm) • Durero (Sat Jul 04, 2026 7:30 pm) • as_gilbert (Thu Jul 02, 2026 7:44 pm)
