It is currently Thu Aug 13, 2026 1:33 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 56 posts ]  Go to page 1, 2, 3  Next
 Post subject: Challenge Ukelele
PostPosted: Thu Jan 05, 2012 8:40 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I haven't started but I will start the thread first.
I will be building an Ukelele out of woods commonly available in Taiwan and Asia. I have the bridge and fingerboard wood, which is a Macassar Ebony fretboard that was sort of messed up, and Macassar ebony bridge blank. However I am still looking wood for the rest of the instrument. Sourcing wood isn't the easiest thing in Taiwan, while I could probably look for some cypress or lauan or primavera, I really wanted something that looks good. Taiwan does grow some Acacia but I have no stable source of those lumber, as they're generally made into charcoal... although technically I am allowed to simply buy some EIR and use that, since they are indigenous to Asia...
Typhoon Guitars
 Post subject: Re: Challenge Ukelele
PostPosted: Mon Jan 09, 2012 8:18 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Update: I found my wood. I ordered some Padouk billet from a taiwanese dealer. I know its african but it was all I managed to find. I will have to resaw it but its nothing my saw cant handle. I have some narrow lauan sticks I can make necks from, and a cheap spruce top that was obtained in Taiwan.
Typhoon Guitars
PostPosted: Tue Jan 10, 2012 8:16 pm
Last Name: Cox
Sounds like a fun little build... Ukes are just so much fun - and there's so much to like about a well built Uke... The sad part is that so few people ever really get to play a good one... The majority of them are just cheap kid toys sold in department stores - not serious musical instruments like when they are carefully built by a Luthier....
Another idea... A Terz guitar is nearly the same size as a baritone Ukelele.... The major difference is the scale length and 6 steel strings....
PostPosted: Tue Jan 10, 2012 8:29 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I know someone who runs a Ukelele store and he did say that anything more than 600 USD is too much to pay for Ukeleles, because the market just isn't ready for them.
It's a shame because a Ukelele is almost as much work to build as a guitar. The strange thing about markets is that a Violin isn't too difficult to build yet it's not uncommon to see violins costing over 100,000+ USD. If prices really are an indication of the amount of work it took to produce it, you would never see 100 dollar guitars.
Unfortunately I don't think the Padauk I ordered is large enough to make a baritone uke... I was planning on making a Soprano because it's the plan I have...
Typhoon Guitars
PostPosted: Wed Jan 11, 2012 1:12 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Here are the materials for use in my Ukelele:
A big billet of Padauk I will resaw into slices myself. I am now trying to figure out how I am going to do this as this is a HEAVY billet. I don't know if this is African or Asian (I think Padauk can come from either continent) but since the seller only sells Asian woods (including some Taiwanese Teak, Cypress, and Camphor), I will assume this is Asian as well.
A scrap pine board for bracings, a lauan stick for necks, and Macassar ebony for fingerboard and bridge. Also a piece of scrap spruce for soundboard.
Typhoon Guitars
PostPosted: Wed Jan 11, 2012 4:18 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I managed to resaw the billet on my little 10" 1/2 HP bandsaw. It took like 15 minutes to make one cut because I had to feed it in very very slowly, and after the cut I noticed the wheel had some Padauk crud on it so I had to scrape those off, I am not sure what to do to avoid that in the future. I used a 1/2" 4 TPI blade...
Instead of making thin slabs, I have decided to first cut out a 3cm piece first because this billet is HEAVY. The cut is surprisingly smooth, while not completely straight it was fairly good for the kind of saw I have. I will need to plane 2 sides smooth to proceed to the next stage, which is to make 4 thin slab cuts. I should be able to get a top/back side for a tenor ukelele out of this billet.
Typhoon Guitars
PostPosted: Fri Jan 13, 2012 9:29 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Here is the set resawn. I think I need a better fence setup because The thickness was variable, being too thick on one side and too thin on the other, thankfully Ukelele boards doesn't need to be very thick.
Typhoon Guitars
PostPosted: Thu Jan 26, 2012 2:23 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
More update:
Thicknessed the back and the side. Since Padauk is supposed to be harder to bend and ukelele bends are somewhat sharp, I made the side about .070" thick. I also thicknessed the top as well, to about .090".
I also made a form for the ukelele. I will do a video on the bending process.
Typhoon Guitars
PostPosted: Wed Feb 01, 2012 1:51 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Typhoon Guitars
PostPosted: Wed Feb 01, 2012 2:28 am
Last Name: Kincheloe
Nice bending! Heck of a lot faster than I've ever managed to do it.
PostPosted: Wed Feb 01, 2012 2:31 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
The key is to get it thin enough... on a small instrument it's almost like bending guitar cutaways so thin your side to match.
Also get the iron nice and hot.
Typhoon Guitars
PostPosted: Thu Feb 02, 2012 5:12 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Laminated neck blank made from reclaimed lauan/meranti/philippine mahogany and padauk/rosewood/maple veneers.
Neck blank profiled, ready to accept a fingerboard and carving. I may need to lengthen the heel, but now I am deciding on a mounting method. Either I try and cut a dovetail or I will do a butt joint bolt on neck with only one bolt.
Typhoon Guitars
PostPosted: Thu Feb 02, 2012 3:21 pm
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
Very nice work thus far. I also like the bound fingerboard/neck in the background of the final picture. I look forward to seeing more progress.
Darrin
PostPosted: Thu Feb 02, 2012 3:26 pm
City: chicagoland
State: illinois
i'd like to see the bending rig in more detail....
PostPosted: Thu Feb 02, 2012 10:28 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
It's just a steel pipe with a torch inside... nothing fancy.
Typhoon Guitars
PostPosted: Fri Feb 03, 2012 5:38 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Looks good Tai.
If I made a bending vid it would be a lot longer!!!!!
PostPosted: Wed Feb 08, 2012 11:34 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Heel and tail block glued. Didn't take a picture of the tail block though...
Typhoon Guitars
PostPosted: Tue Feb 14, 2012 5:36 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
End graft glued.
Typhoon Guitars
PostPosted: Wed Feb 15, 2012 9:22 pm
Last Name: Cox
I like that contrast... I would have thought that Padauk would be way too red - but it looks pretty good in your pix - especially with the maple and the darker purflings...
PostPosted: Wed Feb 15, 2012 9:23 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
To be fair... I heard Padauk darken with age.
Typhoon Guitars
PostPosted: Thu Feb 16, 2012 3:39 am
Yeah it darkens toward a dim brick-red.
PostPosted: Tue Feb 21, 2012 8:30 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Top just went on
Typhoon Guitars
PostPosted: Tue Feb 21, 2012 9:22 am
First name: Tony
Last Name: C
City: Brooklyn
Looks good! I promised to make an ukulele for a cousin but I keep putting it off. Your thread has inspired me to get it in the line up for next winter's builds. Keep the pics coming!
http://www.CostaGuitars.com
PMoMC
PostPosted: Sun Feb 26, 2012 3:18 am
Hello! Tai,
The neck and tail blocks look too big to me. What is the dimension you used?
Normally, I would use 1/2" for tail block and 3/4" for the neck block.
Just a thought...
JC
PostPosted: Sun Feb 26, 2012 3:25 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
UkeforJC wrote:
Hello! Tai,
Just a thought...
JC
I don't know the dimension... I only followed the plan and it was the size listed on the plan. Is there anything wrong with having a big block?
Typhoon Guitars
