It is currently Thu Jul 17, 2025 10:37 pm
 Post subject: Resaw spalted maple
PostPosted: Thu Mar 25, 2021 12:28 pm
First name: Brad
Last Name: Combs
Hello,
I picked up the angel wing spalted maple set from the classifieds. The back set can be resawn into two sets. Should I stabilize it first with CA and then resaw or resaw first? Any special considerations for the resaw? This is the first time I’ve worked with spalted maple. It’s a little intimidating. :)
Brad
 Post subject: Re: Resaw spalted maple
PostPosted: Thu Mar 25, 2021 2:53 pm
First name: Chuck
Last Name: Skarsaune
City: Butler
Huh, I didn't even know the classifieds were still a thing.
Is it worth the $?
I've only resawn spalted hickory for endgrafts, rosettes, and headplates, ie, small stuff.
I haven't stablized it at all, but I wasn't working on a big item.
These users thanked the author Skarsaune for the post: bcombs510 (Fri Mar 26, 2021 7:36 am)
PostPosted: Thu Mar 25, 2021 3:51 pm
City: U.P.
I haven't cut sides or backs but like Skarsaune a fair amount for rosettes and headplates and other projects.
I never did anything different to cut it than any other wood. It often seems to be slightly softer than undecayed wood of the same species but if the decay has gone too far (punky) I'd work around it or try to make it more stable with CA or some other wood hardener.
One thing to be careful of is the dust as the mold can cause serious reactions in some people. Read up on the hazards involved.
Good cleanup and PPE should also be considered. A banjo builder friend got some dust in a cut or rash and had a pretty severe reaction that required hospitalization if I remember correctly.
I've cut a LOT of maple for firewood, and a lot of it ended up with some spalting and a lot of dust was inhaled in the woods without a problem but I may just not be sensitive to it ... yet.
That was a beautiful set!
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: bcombs510 (Fri Mar 26, 2021 7:35 am)
PostPosted: Thu Mar 25, 2021 4:10 pm
Last Name: Ball
I had a shop stash of good 3M N95 masks before Covid struck for just such occasions...
These users thanked the author ballbanjos for the post: bcombs510 (Fri Mar 26, 2021 7:35 am)
PostPosted: Fri Mar 26, 2021 3:15 am
Interesting, I never thought about it being more dangerous because of the spaltting. Good to know, thanks!
These users thanked the author Pmaj7 for the post: bcombs510 (Fri Mar 26, 2021 7:35 am)
PostPosted: Fri Mar 26, 2021 6:26 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I resaw it as is. If it's too soft to saw, I don't use it. I do saturate it with thin CA once installed. I've worked with spalted Maple for decades and have never had any reaction to it.
It will probably be alright.
These users thanked the author Greg Maxwell for the post (total 2): Pmaj7 (Sat Mar 27, 2021 11:48 am) • bcombs510 (Fri Mar 26, 2021 7:35 am)
PostPosted: Mon Apr 05, 2021 7:00 pm
Once the wood has been dry for at least a couple of years, the fungi that created the spalt should be dead, however, there will still be viable spores present that could generate if they found moist growing conditions like the inside of one's lungs. This isn't common but some people are more sensitive to fungal infections.
These users thanked the author Barry Daniels for the post: bcombs510 (Tue Apr 06, 2021 6:37 am)
PostPosted: Mon Apr 05, 2021 10:24 pm
Brad, so glad you asked the question you did as I have a few larger wood turner blocks of spalted maple that I bought years ago on eBay in anticipation of using for a rosette and end grafts. I have watched several wood turner YouTube videos wondering how the blocks didn't explode on a lathe but and I am still too chicken to commit to a bandsaw without stabilizing it some how. I have no sense for how soft/spongy my blocks are relative to the videos I have watched.
I am selfishly curious as to how you make out and how you stabilize it. It can be gorgeous stuff and I think would beautifully accent a guitar depending on the species of backs and sides chosen.
These users thanked the author Anthony Z for the post: bcombs510 (Tue Apr 06, 2021 6:37 am)
PostPosted: Mon Apr 12, 2021 1:09 pm
Last Name: Howell
City: Atlanta
State: Ga
MinWax sells a product called Wood Hardener that I have used many times to firm up punkey wood so it can be turned. CA glue does same thing on smaller scale.
These users thanked the author BobHowell for the post: Anthony Z (Tue Apr 13, 2021 2:15 pm)
PostPosted: Mon Apr 12, 2021 4:19 pm
What happens if you vacuum fill the wood with plastic when you then try to bend it on a bending iron? For example. does the plastic melt and make a mess?
Users browsing this forum: Michaeldc and 29 guests
