It is currently Mon Jul 21, 2025 9:07 am
 Post subject: bridge vacuum clamp cual
PostPosted: Sun May 09, 2021 5:30 am
The first article I saw on clamping bridges with a vacuum clamp showed a somewhat elaborate process of casting foam plastic to the shape of each bridge for a caul. Is that really necessary?
PostPosted: Sun May 09, 2021 7:06 am
First name: Brad
Last Name: Combs
I use this one for guitar and a homemade smaller one for ukes. No caul is used on top and none needed inside .
https://youtu.be/YCGncLvgxp4
These users thanked the author bcombs510 for the post: wbergman (Mon May 10, 2021 7:13 am)
PostPosted: Mon May 10, 2021 2:53 am
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
No caul is necessary. You just need to make sure with vacuum clamping that no air pockets are created -- you want the vacuum to spread all throughout equally. And that should n't be an issue at all with a bridge clamp. The beauty of vacuum clamping is that you don't need any cauls at all and it is also extremely fast - you can get you pieces clamped in seconds.
These users thanked the author Toonces for the post: wbergman (Mon May 10, 2021 7:13 am)
PostPosted: Mon May 10, 2021 7:44 am
Only thing, for me anyway, the maximum clamping pressure is less than 15 pounds/square inch - just sounds a bit on the low side to me, quite a bit less pressure than clamps.
The fit of bridge to top would have to be pretty perfect.
These users thanked the author Colin North for the post: wbergman (Mon May 10, 2021 11:31 am)
PostPosted: Tue May 11, 2021 8:01 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
I had some issues with the diaphragm on my LMI vacuum caul staining lacquer. It penetrated and had to be sanded out. Now I use a piece of thin mylar cut to fit inside the gasket as an overlay to keep the diaphragm off of the finish. LMI was aware of the issue and said that their new material would not cause such problems, but I use the mylar anyway.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Tue May 11, 2021 10:00 am
The difference is in the way the clamping force is distributed across the part. A clamp presents a point load on part and pressure radiates out from that, so as you move away from the clamp, pressure falls off quickly, so we us lots of clamps to make up for that. A vacuum clamp applies the pressure evenly across the entire surface, it's like having an infinite number of clamps, so in reality you don't need as much clamping pressure as you're not relying on it to spread from a single point of a clamp.
15 psi may not sound like a lot, but consider this; a 10" x 10" area has 1500 pounds setting on top of it (10 x 10" x 15 psi) . That's equivalent to approximately a 10" x 10" x 4 ft piece of steel.
These users thanked the author Jim Watts for the post (total 2): wbergman (Wed May 12, 2021 10:33 pm) • Pmaj7 (Tue May 11, 2021 10:54 am)
PostPosted: Wed May 12, 2021 5:38 pm
Yeah, I remember the first systems. They said you had to mix up a batch of a special foam to cast a mold of your bridge, and the casting was used as a caul over the bridge and then the vacuum clamp went over that. AND you had to cast a new caul for every different bridge you used.
These users thanked the author bftobin for the post: wbergman (Wed May 12, 2021 10:32 pm)
PostPosted: Sat May 15, 2021 10:52 am
And a 1.25 x 6.25" bridge would only have 117lbs total on it. A single cam clamp can exert a force of 330 lb.
These users thanked the author Colin North for the post: wbergman (Sat May 15, 2021 1:59 pm)
PostPosted: Sat May 15, 2021 3:07 pm
What's the force provided by a go-bar
PostPosted: Sat May 15, 2021 3:41 pm
About 8 lb per
These users thanked the author Pmaj7 for the post: wbergman (Sat May 15, 2021 4:44 pm)
PostPosted: Sat May 15, 2021 4:31 pm
First name: Aaron
I made a caul similar to LMI, and I couldn’t get it leak free, so I went REALLY simple and cheap.
Ditto to Toonces above!
Personally, vacuum clamping with hhg seems TOO natural. The clamping pressure is enough to dent the bridge (I mention this in the vid after 2:12), and the vacuum dries the glue so fast! If you have a compressor, no reason for clamping, and every reason to trash the go bar. Which I did. I have a jig for top and back braces as well.
Go to 2:12 to see the caul in action.
https://youtu.be/i_yE4EbHORk.
These users thanked the author Aaron O for the post: wbergman (Sat May 15, 2021 4:48 pm)
PostPosted: Tue May 18, 2021 1:14 pm
The bridge on my personal guitar was clamped under vacuum, and it’s holding up well after five years. A lot of people like Simon, who build full time, also use vacuum to clamp bridges routinely. Based on that and my own first hand experience, I’m perfectly comfortable using vacuum.
My experience with the LMI clamp was similar to Casey’s though. The membrane left a dark silhouette around the bridge, which (thankfully) went away on its own over time. They sent me some new membrane material to replace it with for the future, but I haven’t had the opportunity to use it yet.
These users thanked the author James Orr for the post: wbergman (Tue May 18, 2021 7:06 pm)
PostPosted: Wed May 19, 2021 6:45 pm
"A vacuum clamp applies the pressure evenly across the entire surface, it's like having an infinite number of clamps, so in reality you don't need as much clamping pressure as you're not relying on it to spread from a single point of a clamp. "
Over time, I've found that I do not need as much clamping force as I used to think was nessesary.
These users thanked the author Elman Concepcion for the post: wbergman (Thu May 20, 2021 12:26 am)
Users browsing this forum: guitarjtb, roby and 15 guests
