It is currently Tue May 05, 2026 8:49 am
PostPosted: Sat Dec 23, 2023 11:50 pm
I bought a used LMI rosette cutter for the drill press a while back. I need some replacement blades, but can no longer find them at LMI. Does anyone have a source for the blades.
Do you know if a blade is available to cut a .030" channel. The smallest blade I have cuts a 1/16" channel.
PostPosted: Tue Dec 26, 2023 9:02 am
Anyone?
PostPosted: Tue Dec 26, 2023 10:50 am
I assume this is the tool you have: https://www.youtube.com/watch?v=3aGMy0nXp6U
For something as thin as .030" You might regrind something like an old pocket knife blade or even a Stanley knife blade. For thicker inserts you could buy a length of tool steel and regrind it to various widths.
Unless you are doing multiple rosettes to the same dimensions that tool looks like a PITA to set up and test (O'Brien seemed to indicate as much at the end of the video).
These users thanked the author Clay S. for the post: Pmaj7 (Wed Dec 27, 2023 2:59 pm)
