It is currently Tue Aug 19, 2025 8:41 am
PostPosted: Wed May 25, 2011 6:08 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
...and built a downdraft table. I thought I'd share some pictures.
I've already had a system in place for my knifemaking tools, but I finally got tired of having piles of wood chips sitting around, catching on fire whenever I do some forge welding. [headinwall] :D
I got a Grizzly 1 HP unit this time.
First, a few pics of the table being built. It's just a simple box that hooks up to the vacuum line.
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Wed May 25, 2011 6:09 pm
First name: Phillip
Last Name: Patton
City: Yoder
Now the air system itself. The exhaust from most of the tools goes straight outside. But the planer makes a lot of chips, so I have that going through a cyclone separator first.
Regards,
Phillip Patton
PostPosted: Wed May 25, 2011 7:56 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Hi Phillip- Did you put any supports under the pegboard, or does it just sit on the cleats around the inside of the box?
Alex
PostPosted: Wed May 25, 2011 9:35 pm
First name: Phillip
Last Name: Patton
City: Yoder
Alex
Hi Alex,
I used a brace across the middle to support the perf board, then a vertical brace going from that one to the bottom. I'll take a picture of the inside for you.
Regards,
Phillip Patton
PostPosted: Sat May 28, 2011 4:23 pm
Last Name: Charnock
Country: UK
What have you put over the pegboard ?
Looks like a non slip matting ?
PostPosted: Sun May 29, 2011 11:16 am
First name: Phillip
Last Name: Patton
City: Yoder
Yup, that's it exactly. It's foam mesh of some sort. I'm using it to protect the guitar from scratches while working. The non-slip property is actually pretty irritating...
Regards,
Phillip Patton
PostPosted: Sun May 29, 2011 12:29 pm
Last Name: Charnock
Country: UK
I have seen plan somewhere of a sanding table which is very similar to this. The only difference is that it has two boards set at an angle inside the box which directs falling dust down to a gully where it is sucked in by the extractor.
I think Grizzly do downdraft table inserts with rubber grommets around the holes, I thoughy they were two small to be practical for guitar size work.
I will be making something similar myself soon, thanks for the tip on the mat. I wonder if there is an alternative material that would do the same job?
PostPosted: Sun May 29, 2011 12:45 pm
First name: Alex
Last Name: Kleon
City: Whitby
Hi John- You could use a router pad, or an open mesh drawer liner from any store that sells kitchen ware. I've used the drawer liners for sanding/router pads. They aren't really sticky, and if you get them from a dollar store, they are inexpensive. They also come in lots of nice colours!
Alex
Users browsing this forum: johnparchem and 42 guests
