It is currently Mon Aug 18, 2025 7:51 am
 Post subject: Minimum side length?
PostPosted: Fri Jul 27, 2012 3:12 pm
First name: Jonathan
Last Name: razo
City: dallas
State: tx
I am about to buy a board and was wondering what the minimum side length would accommodate a Small jumbo or OM sized guitars?...usually i let me sides be at at least 32" but i was curious if i could get by with anything less? that way i can plan how to resaw the board.
Thanks in advance.
Jonathan
 Post subject: Re: Minimum side length?
PostPosted: Fri Jul 27, 2012 3:57 pm
I have a 000/OM plan in CAD and the sides measure 29-25/32" in length. It's based on a 14 fret to body Martin style OM, which is 15-1/4" wide at the lower bout. You could probably get by with a little shorter sides if you got creative around the tail wedge and/or neck heel.
PostPosted: Fri Jul 27, 2012 5:43 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Do you use an outside mold? Put a piece of tape along the inside of the mold. This will give you the exact side length.
PostPosted: Fri Jul 27, 2012 8:26 pm
First name: Ringo
Drednought: 30-1/2"
Classical: 29"
OM: 29-3/4"
I would like to know SJ as well.
PostPosted: Sat Jul 28, 2012 4:33 pm
My OLF SJ mold measures 29 9/16".
PostPosted: Sun Jul 29, 2012 6:58 am
Just remember, those are measurements for a full bouted guitar, not a cutaway.
