It is currently Sat Aug 16, 2025 6:36 pm
 Post subject: Binding jig opinions.
PostPosted: Sun Jun 02, 2013 8:03 am
I'm in the process of building a binding jig but would like some opinions on what the best design is. Either, the Williams type jig ( moving the router around the guitar body) or the stewmac jig ( moving the guitar thru the router jig) .I have lots of space so that is not a factor. Appreciate any evaluations.
Sent from my GT-P3113 using Tapatalk 4 Beta
Under Compensated Nut!
PostPosted: Sun Jun 02, 2013 8:51 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Williams jig/Ridgid trimmer/Stewmac bits & bearings. Four guitars so far with no problems.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Sun Jun 02, 2013 8:56 am
You'll find tons of opinions on both if you search the archives, as I'm sure you know People seem generally to like the one they went with (big surprise). I like the Williams (which, you know, is the one I went with :) )
(ps This is the perfect question for a poll, if we had that option.)
Milton, ON
PostPosted: Sun Jun 02, 2013 9:08 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
Agee with Dave. I've only tried one design, the Williams type, and because of the effort going into building the jig, I haven't made a comparison with any other. It does take some room and I'm space limited so it is a pain to set up and take down, but probably only takes 30 minutes or so. Like Casey, I've got the SM bits and bearings, but I use a Colt router.
PostPosted: Sun Jun 02, 2013 9:47 am
I built a Ribbecke style (kinda like the stew Mac) station in my shop. Bought routers for each cut. It's mounted directly to the wall so it's very stable. Never comes down, never needs to be set up. Worse you ever have to do is change a roller if you need a different depth cut. With the routers out of the jig and wall mounted, the bench it's on is still useable as a work bench....
PostPosted: Sun Jun 02, 2013 7:43 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
StewMac True Channel jig, Ridgid router, LMI cutter and bearing set.
Fred
Fred Tellier
