It is currently Wed Apr 29, 2026 10:55 am
 Post subject: Heat Resistant Glue
PostPosted: Mon Jan 15, 2018 5:40 pm
First name: Danny
Last Name: Vincent
Hello Community!
On the neck I'm currently working on, I would like to make the backstrap with back offcuts. This will require a book matched centre joint. I have done this in the past. They require a little touch on the pipe to bend them into the volute. I have had the joint open up a touch in the past. No biggy on darker woods but this isn't.
Any opinions on best glue for this?
Thanks!
 Post subject: Re: Heat Resistant Glue
PostPosted: Mon Jan 15, 2018 5:48 pm
State: Tennessee
Possibly Titebond III I use it when I glue up binding strips its come out of the bender with no issues. Glue up a test dummy and see what happens.
PostPosted: Mon Jan 15, 2018 5:55 pm
Yeah, TB 3 seems to be pretty good for purflings, so maybe it'll work for that application too. I don't do a lot of them, but when I do, I usually thin the backstrap down enough to not require heat to bend. I guess it depends on the radius of the volute...
PostPosted: Tue Jan 16, 2018 4:26 am
First name: Miguel
Last Name: Bernardo
Country: portugal
Started using PU glue for purfs sometime ago. They bend easily and never delaminate. TB 3 also works but introduces a lot of water and I ended up with twisted/cupped stuff if I used it on large surfaces.
PostPosted: Tue Jan 16, 2018 4:27 am
First name: Miguel
Last Name: Bernardo
Country: portugal
Sorry, just realized you only need to joint halves. Not much cupping in that.
PostPosted: Tue Jan 16, 2018 3:28 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
I have also had success with TB3 in a similar situation. But if you get it too hot, anything you use will give way.
Users browsing this forum: No registered users and 342 guests
