It is currently Sat Jun 13, 2026 7:02 am
PostPosted: Fri Aug 25, 2006 9:04 am
Hi so I routed the binding channel too thin at one point and then being careless using the scraper almost thinned the binding away to nothing. Just wondering what you guys would suggest the bindings are just black i was wondering whether to cut that section out and use epoxy to rebuild the binding there.
cheers!
kurt.
PostPosted: Fri Aug 25, 2006 9:13 am
I'd route it off and start over, making sure the binding ledge is accurate all the way around.
PostPosted: Fri Aug 25, 2006 9:16 am
What Paul said. I think most of us have done this. I know I have.
PostPosted: Fri Aug 25, 2006 9:47 am
cheers guys
PostPosted: Fri Aug 25, 2006 10:14 am
Been there, done that.
Route em out and start over.Jim_W38954.801875
PostPosted: Fri Aug 25, 2006 12:24 pm
Yeah, the problem is how you cut your channels, let us see your set up.
We have all been there.... Don't worry. Just do it again.
PostPosted: Fri Aug 25, 2006 10:10 pm
Hi Kurt,
If youre scraping bindings then make sure you keep the scraper registered against the top/back or sides. If you run the scraper at an angle across the bindings then youll get into trouble.
Like others here I'd be interested to see how you routed out your binding channels.
Onto another subject...did you ever sign up for Paddy Burgin and Dave Freemans guitar making course in Wellington in January next year?
PostPosted: Fri Aug 25, 2006 10:35 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
If your binding is 1/4", do I route exactly to 1/4 " or do I leave a scooch so that the binding will be the same scooch above the top?
What is a scooch? If you don't know, what are you doing making guitars and a member of this forum. Knowing measurements is key to building!
PostPosted: Fri Aug 25, 2006 11:18 pm
Scooch is something I prefer without water or ice.
PostPosted: Sat Aug 26, 2006 2:52 am
[QUOTE=kiwigeo] Scooch is something I prefer without water or ice. [/QUOTE]
Heh!
Actually, a "scooch" is more than a "hair," but less than a "bit." Clear now?
PostPosted: Sat Aug 26, 2006 3:36 am
Last Name: Johnson
State: CO.
Funny guys , but could you add explanation on whether I leave a scooch or rout to exactly 1/4"
PostPosted: Sat Aug 26, 2006 3:40 am
Bob, I try to get mine as exact as possible. But if there is any difference in the rabbit and the binding you need to have it a scooch proud rather than a scooch low. It is much easier to scrape down a little binding than it is to scrape or sand down the top, if you know what I mean.
PostPosted: Sat Aug 26, 2006 5:39 am
[QUOTE=Dave Rector] Bob, I try to get mine as exact as possible. [/QUOTE]
Yeah... me too... I wonder why?
PostPosted: Sat Aug 26, 2006 5:52 am
And as I found out on my last guitar, if the binding is a scooch low it makes it more difficult to push it down to the bottom of the ledge during glueing.
Greg
Gwaltney Guitars
