It is currently Fri Sep 19, 2025 4:33 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Sat Apr 16, 2005 11:24 am
Mr. Michael(crazy man),
You do have some good ideas, and I like them. I will be tracking all suggestions, and the ones that are relatively easy to do, have demand, and are low cost to produce will be the first one out. These may make it by the end of summer. Thanks for the suggestions!
Regards,
PostPosted: Sat Apr 16, 2005 12:18 pm
No need to ask how I know this but it is a good idea to not get in a hurry and then forget to put the screw in the bit ....or you might have to do something "creative" like this.....
I call them birthmarks!!!
PostPosted: Sat Apr 16, 2005 12:22 pm
Nice boot tips
PostPosted: Sat Apr 16, 2005 12:23 pm
this is a better pic, I think. They came out clean but the real trick was in getting the second two to match the mistake!
Brian Hawkins38458.9018287037
PostPosted: Sat Apr 16, 2005 12:35 pm
Hard to see but there is red purfling that goes around the fig sapele "boot tips" as well as the around the binding. I got that sinking "OH NO" feeling when it happened then I just turned everything off and went inside and sat down
PostPosted: Sat Apr 16, 2005 1:51 pm
Brian,
I'm not sure I understand what happened. You forgot to screw the bearing onto the tip of the bit? Or did you forget to tighten the colette for the bit? And please tell me you didn't make this mistake with one of the bit/bearing sets I sold you!
PostPosted: Sun Apr 17, 2005 5:57 am
Just got in a hurry late at night and forgot to put the screw in.....if I remember correctly I got the set from stewmac.
PostPosted: Sun Apr 17, 2005 8:21 am
That's a tough repair I've never had that happen (yet) but I think I might repair it with a knot or maybe something commpletely contrasting. How did you fix it?
PostPosted: Mon Apr 18, 2005 12:34 am
I used figured sapele for the rosette and thus also for the repair. The "thumbnail" (as I call it) was the same radius as a quarter so I measured from the center stripe to the other side, marked it and in an act of bravery used the same router bit (no bearing) to cut the adjascent "thumbnail" and then centered one at the top doing the same thing.....used alot of light!! The links below show clearer pictures. The recipient of the guitar just thought it was the coolest thing go figure!!
IHADASCREWLOOSEANDNOWTHREETHUMBNAILS
IHADASCREWLOOSEANDNOWTHREETHUMBNAILS2
PostPosted: Mon Apr 18, 2005 12:01 pm
were your knees knocking when you went to make the second...?
crazymanmichael38460.8779398148
PostPosted: Mon Apr 18, 2005 1:22 pm
I took a deep breath and just dove in head first...with caution!!
