It is currently Thu Sep 18, 2025 10:21 pm
PostPosted: Sun Apr 24, 2005 11:52 pm
Guys - Im doing a repair on a gutiar that was finished with Nitro - I have it buffed out with menerznas 3compounds and still have those swril marks. What should I try next?
PostPosted: Mon Apr 25, 2005 12:02 am
If they are tiny, I have had good luck with Finnesse It. It is a 3M product. I think LMI sells it if you can't find it locally.
PostPosted: Mon Apr 25, 2005 12:14 am
Which Menzerna compounds did you use the cans of paste or the dry 3-pound bars?
PostPosted: Mon Apr 25, 2005 12:19 am
Lance, the Maguire's polishing compounds work well. I think it is the number 7 that's used for this. I got the tip from Mario a year or 2 ago.
You can also find them locally, which is a plus.
PostPosted: Mon Apr 25, 2005 12:35 am
I have always had good results with the Maguires #7.
PostPosted: Mon Apr 25, 2005 12:39 am
I used the 3 bars from Grizzly - and Brock _ tried the fennissit it 1 2 and the glazing compound - and it gives it a blush look.
Ill stop and get some Maguires today.
Thanks Guys.
PostPosted: Mon Apr 25, 2005 12:50 am
Lance,
Unless the area is just too big...I always use the Micro Mesh on Nitro repairs. Take it up to 12K and it should be like new...no marks!
PostPosted: Mon Apr 25, 2005 12:56 am
If I have one that blushes or hazes I have followed that up with a water/soap buffing.
D.L.
PostPosted: Mon Apr 25, 2005 12:57 am
no micro mesh
PostPosted: Mon Apr 25, 2005 12:59 am
micromesh 12,000 is way coarser than any polishing compound. If Meguiar's #7 won't get it out, start with #9.
You positive this is nitro, and not polyester? Nitro's a breeze to buff.
This repari started out with 6 spots where the PLASTIC bindings had pulled away from the sides, both at the waist and in the cut away. I tacked each spot down with CA, and after sanding and leveling - and appying the nitro - all the spots have seemly come together on the back side, they just kept growing - so ive buffed the entire back out, the side areas were kept smaller.
PostPosted: Mon Apr 25, 2005 1:01 am
What kind of guitar?
PostPosted: Mon Apr 25, 2005 1:15 am
C-Fox
PostPosted: Mon Apr 25, 2005 1:16 am
Mario -
I was told it was Nitro by its owner - plus the nitro im using is burning in real nicly.
PostPosted: Mon Apr 25, 2005 2:18 am
Lance:
Are you using 3 SEPARATE and CLEAN buffing wheels? If not then you will have marks because the coarser compounds are still impregnated in the buffs.
My last Menzurna compound is "Very Fine" and I have never had any marks in nitro with it. I follow up with McGuires #7 for a slippery and shiny surface.
tim...
PostPosted: Mon Apr 25, 2005 2:31 am
Yup 3 different clean buffs - I think i need to try the Meguiar's
PostPosted: Mon Apr 25, 2005 2:47 am
#9 sweril remover then #7 polishing compound
PostPosted: Mon Apr 25, 2005 3:05 am
do you apply with a rag? and can this be bought as a local auto supply shop?
PostPosted: Mon Apr 25, 2005 3:24 am
Lance, I just use a clean t-shirt type of rag and yes, I got it at the local auto body paint store.
PostPosted: Mon Apr 25, 2005 3:54 am
Lance, scratch head, beat against wall if required, re-think plan of attack. I think chances are somewhere between polishing grits all the scratches from the previous grit were not removed or you started too fine. If you go too fine too soon the deeper scratches just won't go away. I have a shelf full of buffing compounds and polishes to prove this hard learned lesson. Also what others said, clean buffing wheels, polishing cloths, and lots of compressed air and cleaning before the next grit. Good luck.
PostPosted: Mon Apr 25, 2005 4:08 am
You can get it through aout supply retailers. I apply with felt pad on a 1" sq. block, one for each paste. I use vigorus padding motion then buff off with a small 4000 rpm auto buffer with a lams wool cover also a differnt cover for each paste.
PostPosted: Mon Apr 25, 2005 11:35 pm
Lance,
are you still sealing using Z-poxy? Spraying Nitro over the Z?
PostPosted: Mon Apr 25, 2005 11:53 pm
No - i mean yes - im sealing with zpoxy but this was a repair job- I diddnt finish it/.
PostPosted: Tue Apr 26, 2005 2:55 am
I seem to remember Mario posting something about reverse sanding to remove deep scratches. Does this apply here?
PostPosted: Tue Apr 26, 2005 2:58 am
Dont know JJ - IM getting a nice gloss - but id like to take it to the next level and get that glassy finish - Im going to try the Maguires and see if that does the trick - ill keep ya'll posted - thanks for all the ideas and input ..
