It is currently Fri May 15, 2026 6:15 pm
PostPosted: Sat Jan 06, 2007 6:45 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Has anyone been happy using a bench band saw?I`d like to get one I can pick up and move, and still have enough power and cutting depth to cut out necks from a 30x4x3 double neck block.
                            James
James W Bolan
Nashville Tennessee
PostPosted: Sat Jan 06, 2007 7:00 am
I'm real happy so far with my Craftsman/Rikon 10". It's real sturdy for it's size, and has a nice cast-iron table. Nice price, too, I picked up mine for $105 as an open-box.
I've not tried it on neck stock yet, though I think it would probably work okay for a casual/hobby builder if you pay close attention to setting up the saw correctly, get a high quality blade, and go slow. I've cut through 2x4's standing up the long way, and it's done fine. I use Timberwolf blades, Suffolk Machinery will custom make them to length, and the cost is not prohibitive.
If you've got the $$$s, space, and power requirements, I'd go for a 14". If you're putting the saw on it's own stand, it takes up about the same space that a 14" would.
PostPosted: Sat Jan 06, 2007 7:06 am
I should add... I wouldn't want to heft this saw up and down off the bench very often if at all, it's pretty heavy.
PostPosted: Sat Jan 06, 2007 9:46 am
[QUOTE=James W B] Has anyone been happy using a bench band saw?I`d like to get one I can pick up and move, and still have enough power and cutting depth to cut out necks from a 30x4x3 double neck block.
                               James [/QUOTE]
James, ideally the answer would be no, however, when I just had a small shop I used a small bench mounted bandsaw with a 1/2hp motor, and while not ideal, it did cut 3" mahogany on many occasions. Good sharp blade, slow feed rate and don't force it. In an ideal world, you have a bigger machine, but sometimes compromises need to be made. If that's all you have space for then get the best one in the size you can handle.
OK I now have a 13" 80kg machine and a 21" 400kg one, but I built 10 guitars with just the samll bench machine.
Users browsing this forum: No registered users and 45 guests
