It is currently Sat Jul 26, 2025 6:26 pm
PostPosted: Sat Jul 07, 2007 6:45 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I had a lot of fun this morning with the french polish.Sanding it all off and starting over ETC.The back is well, okay And I`d like to start the sides.Do I need to wait a day, or just drink some more everclear and have at it.And how does a person do all the way around the sides without making a mess of it?
                  James
James W Bolan
Nashville Tennessee
PostPosted: Sat Jul 07, 2007 10:16 am
Last Name: Abercrombie
James-
I've only done a couple of guitars in FP, but I found that I could do the back, then one side, top, then other side.
They don't need much (any, really) drying time.
'Drying time' probably depends on your FP mix, the alcohol you are using, and the room temperature, though.
This was working with the guitar resting on a piece of soft carpet and I didn't have problems with 'imprinting'.
However, I did have 'imprinting' problems once, when I left the guitar overnight resting on its side on carpet.
Best to hang it up.
Hopefully some of the FP 'gurus' can chime in here, so you get more expert advice than mine.
PostPosted: Sat Jul 07, 2007 10:18 am
BTW, it's probably easier to just take the FP off with alcohol rather than sanding, when necessary.
Just spread some alcohol-soaked paper towels on the surface for a few minutes then wipe off the FP.
PostPosted: Sat Jul 07, 2007 10:23 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Thanks John.It seems to be real difficult to keep it from building up where the neck attaches to the body.Any ideas there.
                    James
James W Bolan
Nashville Tennessee
Hi James,
I am no expert but when I did mine I did the back, one side, then the top,
and the other side.
With I think two sessions a day, morning and evening
It seemed to work for me.
PostPosted: Sat Jul 07, 2007 11:01 am
[QUOTE=James W B] Thanks John.It seems to be real difficult to keep it from building up where the neck attaches to the body.Any ideas there.
                       James [/QUOTE]
Sorry- I can't help you there- I did the FP before the neck was attached to the body.
PostPosted: Sat Jul 07, 2007 12:22 pm
First name: Jim Howell
James--
Because I finish the necks with Tru-Oil, I also FP before they are attached. You'll want the muneca to be fairly dry during application. If you tap it on a piece of copy paper, it should just barely leave a mark. The back will be dry to the touch within minutes, but it will not be cured -- two separate things. I agree with John that you shouldn't have to sand any off. Alcohol will remove the shellac.
Jim Howell
Charlotte, NC
PostPosted: Mon Jul 09, 2007 5:09 am
back, one side, top, other side.
After 10-12 min the shellac will be dry to the touch. Theoreticly you could start the next body session in a half our or less. How ever I like to give an hour.
