It is currently Tue Jul 29, 2025 2:01 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2
PostPosted: Thu Aug 16, 2007 12:34 am
Well I bent my first set of sides for an actual commissioned guitar lat night with SSII. This is an extremely curly set of Narra from uncle Bob. From past knowledge I know this wood likes to separate at the change of grain orientation in the curl on tight bends. I have also had a bit of faceting issues in the past.
This bend was sweet. got to temp (310) in about 4 min. Bent the waist half way. Did the cutaway in maybe 2 min almost non stop. By the time I got to the back to do the lower bout. It had all but done its self. this photo is kind of an illusion due to angle taken I guess but the entry bend and return or horn bend both are only 1 1/4" radius
Anyway no facets no figure separation, no cracking of any kind at a .090" 2.3mm Just a smooth bend.
PostPosted: Thu Aug 16, 2007 2:02 am
I wonder if SSII would be as effective for hand bending as it is for form bending?  Another possibility, would the wood be plastic enough to bend in an external form with an heat gun and some clamps?  Just thinking out loud.
PostPosted: Thu Aug 16, 2007 2:44 am
I would imagin there gould be no differance in pipe bending and mold bending. External mold, with a heat gun....Man you really want to work hard
PostPosted: Thu Aug 16, 2007 2:51 am
Michael that turned out great. I have been touting the merits of Super Soft II for a couple of years now. I'm very happy to see it worked well for you.
PostPosted: Thu Aug 16, 2007 3:05 am
I don't think I will bend anything without it anymore.
PostPosted: Thu Aug 16, 2007 3:13 am
This set Did scare me a bit. I had treated the wood and wrapped in kraft paper as per the instruction on the bottle. When I removed this set from the kraft paper to prepare for bending it appeared that the SSII had discolored the wood but I went a head and bent the set assuming any discolor was on the surface only. After bending the discoloration completely disappeared. On the test sets of Narra you sent me and the other test sets I did there was no discoloration after the treatment dried. I was a bit worried but no problem in the end.
PostPosted: Thu Aug 16, 2007 6:38 am
Michael,
With regards to bending Zirocote, do you still plan on coating the wood with CA before bending or do you think the Super-Soft II is all that is needed?
- Ric
Ric Hollander
Kings Park, NY
http://www.hollanderguitars.com
PostPosted: Thu Aug 16, 2007 7:10 am
I just ordered a gallon if this stuff from veneersupplies.com.  Thanks again for sharing this trick!!
PostPosted: Thu Aug 16, 2007 7:38 am
[QUOTE=Ric Hollander] Michael,
- Ric[/QUOTE]
Two entirely different issue. I coat Ziricote with CA to prevent lateral or with the grain separation. Ziricote is not bad about cracking cross grain is is bad about splitting along a grain line. I would suspect that if I flooded any wood for that mater with CA then the SSII would be useless.
Ziricote is not at all hard to bend. Like I said the only problem is that it will split along the grain line pretty easy. in particularly if there is a bit of a sap pocket along a grain line.
SSI plasticizes the fiber to help prevent cross grain stress. CA bonds or impregnates the wood to help prevent with the grain splits.
PostPosted: Thu Aug 16, 2007 7:40 am
[QUOTE=MichaelP] [QUOTE=Ric Hollander] Michael,
- Ric[/QUOTE]
SSI plasticizes the fiber to help prevent cross grain stress. CA bonds or impregnates the wood to help prevent with the grain splits.[/QUOTE]
Got ya. Thanks.
Ric Hollander
Kings Park, NY
PostPosted: Thu Aug 16, 2007 10:22 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Michael ,I was wondering what the best procedure would be if the main bends were done in a bender and then the cut-away portion was done on a pipe.Should super soft be re-applied or what do you think?
                    James
James W Bolan
Nashville Tennessee
PostPosted: Thu Aug 16, 2007 12:48 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
Wow!!!
I've been sitting on a gallon of this stuff left over from some speaker veneering work I was doing before I got into lutherie. I've been moving for the last three months, so I've not been following the forum very much. I'll definitely use it for the next guitars I buid. Still a couple of months off due to the move.
Gene
PostPosted: Fri Aug 17, 2007 12:14 am
[QUOTE=James W B] Michael ,I was wondering what the best procedure would be if the main bends were done in a bender and then the cut-away portion was done on a pipe. Should super soft be re-applied or what do you think?
                      Jame s
Well Here is what I think. When you treat the wood you want to us absorbent paper on both sides while it dries and you want it weighted down to prevent cupping while it dries.
With that said I don think you could do anything but treat the wood first bend the waist lower bout then the cutaway on the pipe. So do not re-treat.
Now that said Why would you want to do it that way unless you do not have a cutaway press caul.
Anyway the main thing is any time you wet your wood and have to allow it to dry it needs to be maintained in the flat or it will cup.
PostPosted: Sat Aug 18, 2007 12:05 am
I thought I'd give this a try, just a quart to get me going, the amount I build it should last.
Any way $13.50 for a quart, then add $48 shipping, $25 customs handling, and $15 tax and we come to $101 for a $13.50 item. I don't think so!
PostPosted: Sat Aug 18, 2007 12:30 am
Well, I checked out buying a gallon from Veneer Supplies about a year ago, they want $75.00USD shipping to Aussie, no thanks, I reckon I may have to experiment with a mix of glycerin, methylated spirits and water. Either that or do a deal going halves in a gallon with one of our good buddies OLFers in the USA and have them pack and ship my half USPS Any Takers
PostPosted: Sat Aug 18, 2007 4:27 am
How much do you want/need Kim?
