It is currently Wed Jul 23, 2025 5:35 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Wed Sep 19, 2007 2:32 am
Thanks to all who chimed in with their experiences here.  I'm starting final sanding soon (assuming the redo from my binding mistake goes well enough...it took two weeks to get the replacements with the holiday and several failed delivery attempts).  Anyway, I ordered z-poxy, Shellac, Tru-Oil, and KTM-9 from LMI last week and am still tossing around the idea of going with TO on all surfaces vs KTM-9 so that when I finally do get set up with a proper booth I can sand off the TO and go with something "better".  I guess the assumption I'm making is that it will be easier (faster, less mess) to strip the TO than it will be to strip the KTM, but that's pure assumption.
Stuart Brunker
Stuart Brunker
PostPosted: Wed Sep 19, 2007 2:55 am
Doh!  I forgot the link.  I thought these were pretty good for a starting place, as well.
http://lmii.com/CartTwo/TruOil.htm
Cheers,
Stuart
Stuart Brunker
PostPosted: Wed Sep 19, 2007 3:59 am
City: Lawrence
Zip/Postal Code: 66047
[QUOTE=A Peebels]
I agree about buying small bottles. If it sets a month or so after being opened, a hard film will form over the liquid. The oil under the film is fine to use.
Al[/QUOTE]
I store my True Oil up-side down after it's open. I don't get the hard film crust.
PostPosted: Wed Sep 19, 2007 10:12 am
First name: Jim Howell
Here is a shot of my latest neck -- Tru Oil over a MinWax stain on Mahogany -- Tru Oil was the pore filler:
Jim Howell
Charlotte, NC
PostPosted: Wed Sep 19, 2007 2:14 pm
Beautiful, Jim.  How many coats/days did it take to make it look so good?
Oh, and when they say the sanding needs to be near perfect, do they mean P-E-R-F-E-C-T, or just an ordinary, extra careful sanding?
I guess if it comes out cruddy for me, success is only a redo away.
Stuart Brunker
PostPosted: Thu Sep 20, 2007 5:04 am
An oil finish requires more sanding than laquer. Sand carefully and don't skip grades as you progress. I usually sand up through 800 or 1000 grit.
PostPosted: Thu Sep 20, 2007 11:26 am
Stuart--
This was sanded thru 600. It has ten or twelve coats of Tru-Oil that have been lightly leveled with 0000 steel wool dipped in a pan of naphtha. The last two coats were rubbed out with Micro Mesh.
If you use a pore filler, you don't need the extra coats. Four to six would probably do it. It actually kind of hard to mess up Tru-Oil. My first exposure to it was doing rifle stocks for myself and some friends back when.
Jim Howell
Charlotte, NC
PostPosted: Fri Sep 21, 2007 7:02 am
I have decided that since I am doing a drop top and the TO would probably seep/weep into the binding line (the false binding) that I would simply Shoot the nitro. I spoke with the customer he's willing to wait an extra 4 weeks so I think I have it covered. Also , thanks to all who chimmed in, I am going T.O. the neck...I have the time and everyone seems to rave about TO'd necks.
THANKS EVERYONE!
Your advice and comments are much appreciated.
