It is currently Sun Sep 21, 2025 5:36 pm
PostPosted: Wed Oct 03, 2007 9:02 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Will the minis look okay on a headstock about the same size as a Martin headstock? It`s not a slothead.I wanted to try them out, and I was wondering if anyone had used them on a headstock of similar size?
                          James
James W Bolan
Nashville Tennessee
PostPosted: Wed Oct 03, 2007 10:37 am
James, I recently posted pics of these tuners on a ukulele.  I think they would look fine on a Martin.
http://www.luthiersforum.com/forum/forum_posts.asp?TID=13350 #forumTop
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Wed Oct 03, 2007 11:12 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Ricardo,do you drill the same size holes in the headstock? I`ll check out that post.The headstock won`t be shaped like a Martin, just similar in size.
                           Thanks James
James W Bolan
Nashville Tennessee
PostPosted: Wed Oct 03, 2007 11:25 am
James
I have used them on my headstock shape which is very similar in size to a Martin headstock. They look good, better than the full size Gotohs.
Note however, that the gear ratio, at 16:1,  is not as high (or is that low?) as the regular Gotohs.
Mark
PostPosted: Wed Oct 03, 2007 11:27 am
Clarification:
I am referring to the Gotoh mini 510 model.
Mark
PostPosted: Wed Oct 03, 2007 11:54 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Thanks Mark ,those are the tuners I`m talking about.
I`ll give em a try.I don`t see how the slight differance in gear ratio would make much of a differance.Are the specs the same for the hole size to be drilled as regular Gotoh`s.
                        Thanks James
James W Bolan
Nashville Tennessee
PostPosted: Wed Oct 03, 2007 12:24 pm
James, I use a 3/8" drill for the hole size. You'll still need to ream them out.  Rich
Rich Smith
Issaquah, WA
PostPosted: Wed Oct 03, 2007 12:29 pm
James
I believe they do require the same size hole.
I think 16:1 is plenty of gearing for standard scale length guitars. On guitars with scales shorter than 24.9, 18:1 or 21:1 works better.
Mark
PostPosted: Wed Oct 03, 2007 1:10 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I went ahead and ordered some .
                  Thanks Guys
                        James
James W Bolan
Nashville Tennessee
PostPosted: Wed Oct 03, 2007 1:12 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Ricardo,your uke is a real beauty.I may try and build one someday,although I`ve never played one.
                             James
James W Bolan
Nashville Tennessee
