It is currently Wed Aug 13, 2025 7:53 pm
PostPosted: Wed Oct 03, 2007 4:20 am
Anyone have info on how to make a pinless bridge?  Thanks Rich
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Wed Oct 03, 2007 4:32 am
Look at Mike Doolin's site for what I think is the best pinless design out there.
PostPosted: Wed Oct 03, 2007 6:17 am
Thanks Michael I'll check it out.
Rich Smith
Issaquah, WA
PostPosted: Wed Oct 03, 2007 7:36 am
Here is a thread earlier this year on pinless bridges.
PostPosted: Wed Oct 03, 2007 8:16 am
here Mike Doolin's design
PostPosted: Wed Oct 03, 2007 9:28 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Is there any advantage to a pinless bridge?I`m really a lot fonder of the looks of pins, especially un-polished bone.         & nbsp;         & nbsp;  James
James W Bolan
Nashville Tennessee
PostPosted: Wed Oct 03, 2007 11:36 am
I know my Tacoma Chief has a pinless bridge...but you prob know that about Tacoma...if not check it out...
PostPosted: Wed Oct 03, 2007 11:40 am
http://elderly.com/images/vintage/20U/20U-11223_front-detail .jpg
link to photo of their design
PostPosted: Wed Oct 03, 2007 12:26 pm
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
Yeah that Mike Doolin bridges is nice. Is this a patented design.
PostPosted: Wed Oct 03, 2007 12:37 pm
I like the Doolin design a lot.... wonder why..
I do it very much like Mike Doolin. Let me know if I can help.
PostPosted: Wed Oct 03, 2007 12:48 pm
[QUOTE=scotto]
Wow Scotto thats cool!
Rich Smith
Issaquah, WA
PostPosted: Wed Oct 03, 2007 12:50 pm
The Doolin design is nice, but I'm not so sure that seeing the end winding of the string is pretty.
Rich Smith
Issaquah, WA
PostPosted: Wed Oct 03, 2007 11:18 pm
I like the Doolin design too, but if you use Daddario strings with the coloured ends it looks rather stupid. I will be making mine with a routed channel in the rear edge to hide the string ball ends. Got a router bit at last years Woodstock wood show for 5 bucks that will do it perfectly. Marc Beneteau does something similar.
PostPosted: Wed Oct 03, 2007 11:58 pm
Mike Baranik has a great design too.
tim...
PostPosted: Thu Oct 04, 2007 7:23 am
Last Name: Garrish
My design hides the ball ends, as well, though I was considering one where they could be seen. I'm also quite fond of Doolin's design.
Bob Garrish
PostPosted: Thu Oct 04, 2007 7:57 am
[QUOTE=James W B] Is there any advantage to a pin-less bridge?I`m really a lot fonder of the looks of pins, especially un-polished bone.         & nbsp;         & nbsp;  James[/QUOTE]
Personal opinion is no structural advantage maybe a slight disadvantage at lease structurally.
With a pined bridge the force of the ball end of the string puts the top to bridge joint in compression Now the force of the stings on the saddle add a bit of shear. so the one force is fighting the other or the compression of the ball end into the bridge plate and top help counter actelevated the shear of the rotational force on the saddle.
With a pin-less bridge both forces that the stings impart are in shear and or rotation. and only the glue joint is fighting this force.
Of course I am referring to pin-less that are only glued on.
PostPosted: Thu Oct 04, 2007 8:00 am
Personal opinion is no structural advantage maybe a slight disadvantage.
With a pined bridge the force of the ball end of the string puts the bridgeplate and top to bridge joint in compression Now the force of the stings on the saddle add a bit of shear and rotation. so the one force is fighting the other or the compression of the ball end into the bridge plate and top help counter act the shear of the rotational force on the saddle.
PostPosted: Thu Oct 04, 2007 10:40 am
Michael, aren't classicals pinless.  Somehow they survive, maybe because the bridges tend to be much wider.  I guess you are suggesting that putting a pinless bridge of the smaller size is not as strong as using pinned bridge.
Rich Smith
Issaquah, WA
PostPosted: Thu Oct 04, 2007 10:53 am
In reality, classical bridges are narrower, but the strings are tied, and the stress from the nylon strings is not even close to the stress from steel strings.
PostPosted: Thu Oct 04, 2007 11:52 am
For purposes of a uke then the pinless bridge should be no problem.
Rich Smith
Issaquah, WA
PostPosted: Thu Oct 04, 2007 11:55 am
I would say that's the case.
PostPosted: Thu Oct 04, 2007 1:00 pm
[QUOTE=fmorelli] Classicals don't have 180 lbs of pull.
Doolin and/or Elliot seem to have metal stubs which the ball ends attach to. Do those stubs go through to the bridge plate? If so, then you'd reduce the sheer and corresponding concerns about creep.
Peter a few closer photos of yours, along with information on design inspiration and how yours actually is constructed would be wonderful to hear. Thanks for sharing!
Filippo[/QUOTE]
Filipo,
the posts that hold the strings are anchored through the bridge at an angle and go straight through the bridge plate. Because of that the tension is not on the bridge alone but pulls from the bridge plate. IMO it drives the top better....
PostPosted: Thu Oct 04, 2007 3:14 pm
[QUOTE=Bob Garrish]My design hides the ball ends, as well, though I was considering one where they could be seen. I'm also quite fond of Doolin's design.
Bob, thats one beautiful bridge. Rich
Rich Smith
Issaquah, WA
PostPosted: Thu Oct 04, 2007 7:12 pm
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
I read a while back on Fret's.com that Frank wasn't fond of pin
less bridges because he has seen his share of dents in tops when a string breaks. Don't know if that would be an issue with Doolin's style of bridge though.
I really like the look of both Mike Doolin's and Bob's.
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Fri Oct 05, 2007 12:00 am
yep but much much less tension on the strings
Users browsing this forum: Bing [Bot] and 11 guests
