It is currently Fri May 15, 2026 2:54 am
PostPosted: Mon Dec 17, 2007 8:58 am
Hello!
Im new around here and new to guitar building overall.
Im mainly a drummer, but as a project, I thought about building a lap steel guitar. Now, I know that it will most definately be a disaster in terms of sound and looks, but Im doing it mostly for experience, even if I only manage to finish the body.
I was thinking about, what finish I would like it to have, but I couldnt think of anything.
Then it hit me! Stickers! Why not put stickers all over the body?
But..I thought about laqcuering the body too.
It may seem a stupid question, but..should I laqcuer the bare body (just one coat or so), then put the stickers on and then lacquer it again or can I put the stickers the bare wood and then lacquer?
As I said, it may sound stupid, but I want to be sure, just in case by some magical chance I succeed at making something playable.
Anyway, thanks in advance for your help!!
PostPosted: Mon Dec 17, 2007 9:06 am
Stickers are a bad idea if you decide to remove them later. You should check out a couple of books on wood finishing, like Michael Dresdner's. An oil finish like tung or linseed oil is very easy and could be acceptable for a lap-steel, shellac is easy to apply as well and there's a number of finishes that do not require equipment or tremendous technique to get a good result. Lacquer requires a spray booth, it is both dangerous and toxic, besides the fact that there is definitey a learning curve to it, as with any professional finish.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Mon Dec 17, 2007 9:08 am
Well the stickers do not make it moistier resistant. The sickers would make any future repaire a nightmare.
If you take your time and ask for help when needed your steel guitar will not be a desaster and will sound fine.
just type if you need help. That wat we are good at around here
PostPosted: Mon Dec 17, 2007 9:11 am
Thanks for the quick replies!
I see. So the stickers seem like a bad idea, haha.
I'll try to find out more about oil finishes then. And if I have any more questions, I now know, where to go!
Thanks again!
PostPosted: Mon Dec 17, 2007 9:21 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
Say the guitar does turn out to be pretty good why cover it up with crappy sticker. Even if your not any good with finishing a simple wipe on oil finish will look a hundred times better then stickers and its easy. Watcos danish oil is one brand.
PostPosted: Mon Dec 17, 2007 9:23 am
There are lots of easy to apply instrument grade finish available that do not require specalized equipment. Personally I thing French polish is a great choice but brused on shellac. raged on tru-oil, spirit varnishes, Belhen's Rockard varnish, lost to chose from.
