It is currently Tue Jun 17, 2025 7:12 am
PostPosted: Mon Dec 31, 2007 7:14 pm
Can a person put a french polish finish over z-poxy filler? Or must one use
pumice as the grain filler?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Mon Dec 31, 2007 7:42 pm
French polish over Z-poxy is fine.
PostPosted: Mon Dec 31, 2007 9:24 pm
Edit: I should have added, though I think we all know now, that the opposite is not true. Z-poxy does not adhere well to shellac.
PostPosted: Tue Jan 01, 2008 12:53 am
Rich,
All of my guitars are FP over Z-Poxy. It works fine and I have never had a problem.
Best wishes,
Max Bishop
Brighton, Michigan
Max Bishop
Brighton, Michigan
PostPosted: Tue Jan 01, 2008 3:01 am
Great, thank you. Happy New Year all!
Rich Smith
Issaquah, WA
PostPosted: Tue Jan 01, 2008 4:53 am
Hey Max, do you sand back to all wood or leave a thin coat?
Thanks!
PostPosted: Wed Jan 02, 2008 2:55 am
yes FP over Zpoxy is fine
Write this down and post it on your bench some where
Shellac over epoxy is a go!!!
Epoxy over shellac is a no-no!!!
I know! lots of info about here and keeping track is hard Just keep this in mind. Shellac will stick to darn near any thing. but epoxy can be selective.
I know a few that have success with epoxy over shellac but they tooth the shellac. As I mentioned a couple weeks ago I did some practical testing and almost in all test samples I did epoxy over shellac, it was easy to peel epoxy off of a shellac under coat, but the other way (shellac over epoxy) I had no chance of peeling the shellac off the epoxy.
PostPosted: Wed Jan 02, 2008 5:42 am
Rob,
Depends on the wood. I will sand back to wood leaving the pores filled in the case of a wood that I don't wish to darken - like the Cocobolo guitar I am working on now. With most light woods, such as Cypress or Maple, I will leave a layer of Z-Poxy to add some amber coloring.
Max
Max Bishop
Brighton, Michigan
