It is currently Mon Jun 16, 2025 5:19 pm
PostPosted: Mon Jan 07, 2008 4:01 am
PostPosted: Mon Jan 07, 2008 4:05 am
WOW!!! That's impressive!
PostPosted: Mon Jan 07, 2008 4:18 am
Waddy, looks like you've been flat out all weekend- you've gotta slow down man....
It's probably the lightest looking guitar I have seen. She's gonna sound great!!
PostPosted: Mon Jan 07, 2008 4:49 am
I must have blinked.
PostPosted: Mon Jan 07, 2008 4:53 am
Well, that didn't work too well.  Oh well, here goes.  I was able to make some progress this past weekend on my build.  If you are tired of all this stuff, just say so and I'll post when I'm done.
I try to keep myself going on different levels, so things will come together for assembly at the same time.  Some tasks are much more time consuming than I think they will be when I start.  I had worked my sides down some in another session, so I got them down to proper thickness during last week.
Just for Hesh!  *@$%~!  What a mess!
Another thing that had been holding me up was finishing up my "Spring Loaded Go-Bars".  I made 9 more this weekend.  I now have 28, I think enough for now.  I can always make more.  I also made a scabbard of sorts to keep them in.  Coffee Cans with HVAC Aluminum Tape.  The small coffee can holds the spacers that are used when bluing at the Solera surface.  They are removed when gluing on the back.
Here is a shot of my Dowel Sizing
operation.  All 1/2" dowels are not created equally.  I first drive
them through a 1/2" hole, then through a 15/32 hole so they will slide
easily in the CPVC, but not wedge into the spring.
the next thing on my agenda was to finish thinning the edges of my top to the proper thickness, and taper to 2.5mm in the center of the lower bout.  Using a slightly curved scraper and a couple of pairs of calipers set to 1.9mm and 2.2mm, I scraped and tested until I had a fairly even taper from 1.9 at the edge for about 20mm or so tapering up to 2.2 in another 10 to 15mm then to 2.5mm.  I think I have it now.
Next, I had to make sure my bracing patterns were correctly drawn on my plantilla half.  Next, I drilled holes at the center points at the end of each fan brace and top brace.
Next I transferred the layout to the back of the top.
Connecting the dots.
Next, I sized all the fan braces, upper bout braces and closing braces, and laid them out on the top to see how stuff will go together.  I still have to do the rough shaping of the Top Braces that have the cut-outs in them for the upper bout braces.
Thanks for looking.
PostPosted: Mon Jan 07, 2008 4:54 am
I may not be much of a typist Waddy But I can post pictures
PostPosted: Mon Jan 07, 2008 4:55 am
Sure now they show up
PostPosted: Mon Jan 07, 2008 4:57 am
I don't know how that happens.  I know I didn't click on post.  I must have hit enter when out of the text box, with post as the default button.
PostPosted: Mon Jan 07, 2008 5:21 am
Country: Romania
Waddy, it sure is fun to play with the sticks on a blank top, isn't it? :)
When you get to actualy glue them the fun becomes a little way too stressy, but the vertical push bars will make it easier.
Build log
Last Name: Walden
City: Bartlesville
State: Oklahoma
Zip/Postal Code: 74006
Great looking work, Waddy!  I can even count that you still have ten fingers!
The top looks fantastic.
Steve Walden
Aspiring Builder,
Bartlesville, OK
PostPosted: Mon Jan 07, 2008 5:25 am
Very impressive - you do beautiful work my friend!
PostPosted: Mon Jan 07, 2008 6:33 am
[QUOTE=Hesh]Very impressive - you do beautiful work my friend!
I'll never compete with Mr. HESHCLEAN!
PostPosted: Mon Jan 07, 2008 6:45 am
Awesome stuff Waddy. Really nice.
PostPosted: Mon Jan 07, 2008 8:15 am
Very nice work, Waddy! Very nice indeed!
PostPosted: Mon Jan 07, 2008 9:11 am
Looks really good, waddy.
PostPosted: Mon Jan 07, 2008 9:19 am
First name: Danny
Last Name: Vincent
Looks great Waddy! What do you call that cool looking plane standing on
end in pics # 2 and #4. I don't think I've seen one like it.
Cheers,
Danny
PostPosted: Mon Jan 07, 2008 9:21 am
Stanley #12 Cabinet Scraper.
PostPosted: Mon Jan 07, 2008 9:35 am
First name: kurt
Last Name: thomas
City: colden
State: ny
Zip/Postal Code: 14033
Waddy,
I enjoy the pics, us newbies like to build v i c a r i o u s l y.
I know the first pictures did'nt post because your fingers were a little shaky from making the PVC gobar containment system in one day.
_____________________________
Kurt Thomas
"There's a first time for everything even if you do it by mistake."
PostPosted: Mon Jan 07, 2008 10:37 am
Outstanding work Waddy!
I hope this wasnt the top you outbid me on last weekend??
I really enjoy seeing what you are doing on the bracing of the tops of the classical guitars. The bracing is MUCH smaller than I had invisioned. PLEASE keep posting progress pictures??
PostPosted: Mon Jan 07, 2008 1:13 pm
Waddy, Very nice work!
PostPosted: Mon Jan 07, 2008 1:20 pm
Thanks folks, it's easier than taking notes all day.
PostPosted: Mon Jan 07, 2008 1:33 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Have fun cause this is the fun part.  Pretty soon you'll be doing the binding and then you'll be cursing, like I am right now.
Its interesting following your progress, its like Deja vu, because I'm just a couple of steps ahead of you.
http://redrivercanoe.ca/
PostPosted: Mon Jan 07, 2008 6:34 pm
Very productive Waddy!
Now Get Back to WORK!
PostPosted: Tue Jan 08, 2008 2:38 am
Lovely work, Waddy.
Max Bishop
Brighton, Michigan
Max Bishop
Brighton, Michigan
PostPosted: Tue Jan 08, 2008 5:56 am
Enjoyed that, Waddy!
