It is currently Sat Sep 20, 2025 5:45 pm
PostPosted: Tue Feb 05, 2008 11:02 am
City: Grandfalls
State: Newfoundland
Hey guys .....I know that a guitar will sound better and better with age...But is there a seasoning period after final setup....Seems to me that a guitar takes a little while to come into its sound,,so to speak.....Is this the case or is it just me getting familiar to its sound.?...Larry
PostPosted: Tue Feb 05, 2008 11:26 am
Referred to as opening up This takes weeks to months depending on several factors and even then is an ongoing process till the guitar stabilizes some what under tension.
PostPosted: Tue Feb 05, 2008 12:18 pm
First name: Martin
Last Name: Edwards
Yup, it always amazes me the improvement, even overnight, leaving a new guitar strung up.
still, I'm amazed that there's any sound at all when I put the strings onto a new build!!
PostPosted: Tue Feb 05, 2008 1:09 pm
First name: Wayne
Last Name: Clark
City: Driftwood
How long do you wait before you finish the setup? It seems like I should leave the strings under tension for a while before I finish the frets and the saddle.
PostPosted: Tue Feb 05, 2008 1:18 pm
When I complete a guitar I try to play that one all I can until I complete the next one. During this initial period I hear some changes or opening up and I note any issues that I have with the set-up.
If I were doing this for a living I would give them a couple weeks of playing and then tweak the final set-up since things like neck relief will set in.
I also find that Adi topped guitars take far longer to open up but when they do it is very worth the wait.
PostPosted: Tue Feb 05, 2008 1:47 pm
I leave it a week to 10 days...
As for the wood "opening up", I noticed a marked tonal change in the Sitka spruce topped guitar I built after a year of playing it. If I played it more often, I guess it would have opened up sooner.
PostPosted: Tue Feb 05, 2008 1:53 pm
Interestiing note here:
I have always figured that as the spanking new guitar settled in under tension that there would be a significant change in intonation. in particular I expected GDAE to go a bit flat as the guitar opened up. However, though I have noticed a bit of change in the intonation on a few of the guitars I have built, I have no had much if any perceivable change in the vast majority of them. The tone always seems to gain complexity but rarely have I had to re-intonate after break in. don't know if I have just been lucky or what
PostPosted: Wed Feb 06, 2008 10:36 am
First name: Wayne
Last Name: Clark
City: Driftwood
My experience so far is one guitar, so I'm probably over-thinking the problem. I was thinking the same thing, that the string tension would pull the top and bridge resulting in the intonation going flat by some small amount. I have a lot to learn.
Users browsing this forum: Geocoucou79 and 43 guests
