It is currently Tue Jul 29, 2025 2:40 am
 Post subject: Tucker F model mandolin
PostPosted: Thu Mar 20, 2008 1:44 pm
I saw where my son Brad has posted some pic of a Guitar and thought you might like to see one of our mandolins. Its not flawless but, I've never made a flawless one. This is the first one I've built in 5 or 6 years. I just wanted to see if I could still do it. It has a really great sound.
PostPosted: Thu Mar 20, 2008 2:35 pm
Well Melvin, it sure seems like you can still do it!! [clap]
Welcome to OLF. I'd love details on the finishing, if you could share. It looks great!
Milton, ON
PostPosted: Thu Mar 20, 2008 2:39 pm
Gorgeous mando!
Melvin!
Welcome to the OLF!
PostPosted: Thu Mar 20, 2008 3:24 pm
Wow, that's really nice!
And another Welcome to the OLF!
PostPosted: Thu Mar 20, 2008 3:46 pm
I have built a few f-style mandolins and I know how difficult they are to build, much harder than a guitar. Looks to me like you can still do it! The inlay is beautiful and I like the one piece back. Great work!
PostPosted: Thu Mar 20, 2008 6:33 pm
That you all for the good comments. Someone asked about the finish. It is just a basic sunburst that I have used for years. On this mandolin I dyed the mandolin Orange all over. If you want a yellow sunburst dye it yellow first. After that dried I started appling the tobacco brown sunburst with an air bursh. I used water stain here you can probably get a little darker stain using alcohol stain but, it is not as light fast as the water stain. I then applied about 3 coats of thin laquer (Lawrence Mcfaddin) for a sealer and dust coat. Let that dry a day and dust sanded with 320 or 400 grit paper, very lightly just to remove the fuzz, dust etc. Well, then I sprayed 6 to 8 coats of lacquer at 1 hr intervals. Let set for a week or two then level sand with finer and finer grits then go to the buffer. I probably sanded of somewhere around 2 or 3 coat before I buffed it out.
PostPosted: Thu Mar 20, 2008 6:38 pm
Sweet!
PostPosted: Thu Mar 20, 2008 6:39 pm
Simply beautiful.....I sure would be proud to own that if I played mandolin. Gorgeous work Melvin, and a sincere welcome here to the OLF. It's our pleasure to see such fine craftsmanship. Thanks for sharing that!
PostPosted: Thu Mar 20, 2008 8:57 pm
Melvin,
Great work, you haven't missed a beat. I'd love to see more mandolins builds. I'm tossing the idea of a mandolin build.
Mark, I have heard that building an F style is more difficult that building a guitar, can you elaborate on what makes it a harder build? Grumpy, jump right in here, I know you play and build.
Peter
PostPosted: Thu Mar 20, 2008 9:14 pm
She's a beauty Melvin. Nice colors too! [:Y:]
jw ( o)===:::
PostPosted: Thu Mar 20, 2008 9:19 pm
I'm really interested in knowing how you applied the finish inside the curl at the top of the upper bout. I love the look of these F style mandolins and there is no comparison tot he sound they generate. Well done my friend!
PostPosted: Fri Mar 21, 2008 3:56 am
First name: Martin
Last Name: Edwards
It's not flawless he says!!!
It looks GREAT!!
as to mandos being harder than guitars, the attention to detail in a smaller build is more focused. a 3 mm ding on a guitar will be noticeable, but on a mando it'll look HUGE!!!
PostPosted: Fri Mar 21, 2008 4:56 am
I can tell you a few things that make it harder than a guitar.
The binding (bending to tight curves and such) is a bear. Cutting the channel for the binding at the scroll is done freehand, too. gaah
His tops and backs are carved by hand. F holes cut out freehand, too.
everything is smaller, which makes it more difficult.
Those are just a couple of things, but they add up to a lot of time, head scratching, and nerve racking freehand work. It's good for stress relief! gaah [headinwall] laughing6-hehe
Brad Tucker
PostPosted: Fri Mar 21, 2008 7:02 am
Very nice! What did you finish it with?
Terry
PostPosted: Fri Mar 21, 2008 7:27 am
Gorgeous! Love that finish!
PostPosted: Fri Mar 21, 2008 7:24 pm
It is finished with Lawrence Macfadden Lacquer.
PostPosted: Tue Mar 25, 2008 2:33 pm
psl53 wrote:
Melvin,
Peter
Melvin, The reason a mandolin is much harder to build than a guitar (flattop guitar anyway) is 1. carved top and back plates, the scroll spirals around rising as it goes with a cove on either side that rises to a ridge. (hard to put in words) The plates are also carved on the inside surface, just like a violin or archtop guitar. 2. routing the binding channels around the scroll, I use a dremel in a stew-mac router base and let the base rest partially on the scrolls surface and freehand to a pencil line. 3. The headstock has a lot of detailed curves where, again the binding channels are a bear to cut. A lot of freehand work there too. Overall, there is a lot more intricate detail involved on a much smaller body. I guess thats why handmade mandolins are so expensive, even a new Gibson will set you back several thousand. There is a friend of mine here in Bristol that builds mandolins fulltime and has quite a reputation among Bluegrassers, Ray Dearstone, check out Ray's website http://www.dearstone.com/ - 9k - I just like to have a project going all the time, be it a guitar, mandolin, or a fiddle. A mandolin will keep you busy for a long time! I've made seven so far.
PostPosted: Tue Mar 25, 2008 2:35 pm
I'm sorry, my post should have been addressed to psl53 not Melvin. oops_sign
PostPosted: Wed Mar 26, 2008 2:57 am
It looks great, Melvin!
