It is currently Mon Jul 28, 2025 11:20 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Sat Mar 29, 2008 4:11 pm
First name: Gary
Last Name: Lee
The ebony for the armrest is 2.4 mm thick. It starts oversized and is initially bent at about a 20 degree angle across the lower bout of my side bending machine. Then it's bent by hand to a perfect match on a bending iron. After French polishing the top in the area, the armrest is taped into place. Starting at one end of the armrest, I drill a hole through the rest and into (but not all the way through) the upper lining. I tap in a dowel, and continue the process to other end of the armrest so that it ends up in a secure, dry fit. Then I take it apart and glue with T88 epoxy and trim the dowels and armrest.
To hide the pins, I considered overlaying with a veneer but realized with the jet black ebony that a veneer would be unnecessary. Instead I drilled a very shallow dimple in the end of each dowel, stained the dowel with LMI fingerboard dye for good measure, and filled the dimple with dry dye mixed with Z-Poxy. The result was a perfect match that is undectable after French polishing. The case would be trickier had the armrest been made with anything other than ebony (such as rosewood that has obvious grain), but I suspect that a well-matched shaving in the dimple would do the trick. If others make this type of armrest, I'll be eager to hear what solutions and improvements you come up with.
PostPosted: Sun Mar 30, 2008 5:55 am
Cool, Gary. Thanks.
Todd Rose
Ithaca, NY
PostPosted: Sun Mar 30, 2008 6:35 am
Beautiful guitar, Gary. The workmanship looks wonderful and your design is impeccable. Last but not least - it sounds great too!
Congrats,
Max
Max Bishop
Brighton, Michigan
Users browsing this forum: Cal Maier and 11 guests
