It is currently Sun Jul 27, 2025 11:10 pm
PostPosted: Tue Apr 15, 2008 3:39 pm
This quater for shop class i'm going to be building a simple neck thru explorer (electric). In the past i've used a bunch of different kinds of glue, some good and some bad. I'm still undecided and don't want this thing to fall apart at the seams so i need some outside input. What kinds of glue do you guys swear by?(types and brands). On a side note the neck is either going to be all sapele or all paduck laminated together with 2 pieces sitting on top of each other.
andrew
PostPosted: Tue Apr 15, 2008 4:40 pm
Not being an electric builder I may not be the right one to answer this but I would think you would want a reversible bond in case of future repair so I would think Hot Hide Glue first, Fish Glue and even Titebond original will work fine.
PostPosted: Tue Apr 15, 2008 7:52 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
Titebond is good...but even elmers wood glue will work.
The main thing is to get good glue joints.
http://www.PeakeGuitars.com
PostPosted: Tue Apr 15, 2008 8:09 pm
You do not need a reversible bond. On a neck through the most permanent bond is desirable. Hide glue is difficult to work with until you have a bunch of practice and has no advantages for this application. Titebond (Original, not II or III) will work fine and is easy to work with. You might also consider urea-formadehyde glue (Weldwood Plastic Resin Glue is an easy to find brand). It comes as a powder that you mix with water; it has the advantage of greater permanence and zero creep. Good jointing and clamping are important; get the help of your teacher.
