It is currently Sun Jul 27, 2025 2:35 am
PostPosted: Fri Jun 06, 2008 11:13 pm
I am going to make a bending pattern (tenor ukulele) for a Fox style bending machine using a heating blanket. If I layer in this order: lower steel slat, wood, upper steel slat and then the heating blanket on top -----how much compensation (ie. - how much smaller) should I put into the bending pattern to get the best results?
Formerly know as Mandodiddle.
PostPosted: Fri Jun 06, 2008 11:26 pm
Mandodiddle welcome to the OLF! [:Y:] [clap] [clap] [clap]
My stack looks like yours only with a third slat on top of the blanket. I don't use an bending form compensation and it works for me.
I know though that some folks do compensate their forms for the wood and/or stack. I am sure they will weigh-in here and help you out.
PostPosted: Fri Jun 06, 2008 11:41 pm
My bending molds are undersized by .100" all the way around.
PostPosted: Sat Jun 07, 2008 1:15 pm
I make the inside mold first, then use a router template guide to make the outside mold 1/8" larger, which compensates for the thickness of the side and slat. .
David White, Toronto
PostPosted: Sat Jun 07, 2008 5:55 pm
Thanks everybody. What a great place to exchange information. I think I'll try shrinking the pattern within the ranges you listed and see what happens. Again, thanks for your responses.
Bill
PostPosted: Sun Jun 08, 2008 8:04 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
Another thing to think about....some folks over bend the wood on the form so that you can take it right off the form and put it in a mold. Check out the Taylor Factory Friday videos...you can see that the edges of the forms are not vertical and that they are overbending at the ends at a minimum...and probably the waist as well.
http://www.PeakeGuitars.com
PostPosted: Mon Jun 09, 2008 8:27 am
You answered your own question if think about it logically you said you would be using a slat/wood/slat/blanket. Every thing past the out side of the wood is inconsequential to the shape and size of the form
Form compensation = Thickness of one slat and thickness of the wood.
If this is the way you are going to lay out our sandwich.
Personally I would not place my blanket outside for 2 reasons. Loss of heating efficiency and wear on the blanket from the press cauls. I would go slat/wood/blanket/slat or slat/wood/slat/blanket/slat.
In any case if the wood is always the second component from the bottom of your sandwich the amount to compensate for would not change.
Users browsing this forum: Bing [Bot] and 12 guests
