It is currently Sat Jul 26, 2025 8:24 am
PostPosted: Tue Jun 10, 2008 9:39 am
Well, I finally got around to taking my first apart a little over a week ago to finish up the FP process. The back and sides were pretty good, but the top needed a fair amount of work. I had put on a number of bodying sessions over the last week, and last night was glazing. Working away happy as a lark. All of a sudden, I heard the sound of something hard scraping across the top. Yep - fingernail! gaah OK, I did the little oil and 400 grit thing to see if I could sand it out. It wasn't invisible, but I let it go, built the area back up, and went on. In a minute it happened again. I thought I was being careful, but when gliding on and off the top, it's easy to catch the muneca on the edge, apparently. This scratch was long and deep. I ended the night up taking the whole finish off the top, to start over. What a night! I think I'm going to get some of those heavy finger tip protectors for French Polishing. At least that would only leave a rubber mark on the top.
PostPosted: Tue Jun 10, 2008 9:44 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Be glad that's all that happened! You didn't bang it into any machinery or drop it on the floor.
But, yeah, it sucks.
http://redrivercanoe.ca/
PostPosted: Tue Jun 10, 2008 9:45 am
Waddy, good lesson learned! I think I've said before that I always wear a surgical type glove on my right hand when French polishing just for this reason.
PostPosted: Tue Jun 10, 2008 9:57 am
I can assure you I will be wearing some kind of gloves when I do, from now on. I justified it also because I kept seeing things on the top that I did not like. Just little things, but why start with that. It should be as good as I can make it. Hopefully, I am getting better at French Polishing, as I am getting lots of practice. Thanks for your commiserations!
PostPosted: Tue Jun 10, 2008 10:10 am
Yeah wear those gloves that the proctologist wears....... :D
Sorry this happened to ya Waddy bro.
PostPosted: Tue Jun 10, 2008 10:21 am
First name: Jim Howell
Waddy--
I've found out the hard way that you need to remove any jewelry from your hands and wrists and also if you are wearing a shirt with long sleeves and button cuffs, roll them up! The spruce is pretty tender and darned easy to dent. You might be able to steam a lot of it out.
Jim Howell
Charlotte, NC
PostPosted: Tue Jun 10, 2008 10:30 am
When I got down to wood, the scratches were light, and in the upper bout primarily, so I sanded them out. They did go all the way through the finish though. As I said though it allowed me to sand out a couple of other imperfections I had seen after getting finish on the top. Little things don't show as much on back and sides, but sure shine out on the top, don't they?
