It is currently Sat Jul 26, 2025 6:09 pm
 Post subject: Bridge plate thickness?
PostPosted: Sat Jun 14, 2008 10:49 pm
First name: Chuck
Last Name: Hutchison
City: Houston
What is the common thickness of a maple bridge plate on a dreadnaught? Right now it is .125
I checked in the archives and couldn't find anything on it. I have the top braced and this will be the last piece I have to glue in.
PostPosted: Sat Jun 14, 2008 11:20 pm
Chuck buddy I use about .090".
PostPosted: Sun Jun 15, 2008 12:13 am
+1 to what Hesh said
PostPosted: Sun Jun 15, 2008 12:15 am
Don't listen to Hesh. The correct thickness is .089 give or take .001.
PostPosted: Sun Jun 15, 2008 6:39 am
Make that two for .089.
David White, Toronto
PostPosted: Sun Jun 15, 2008 9:06 am
I usually go with .100, sometimes .110
M
PostPosted: Sun Jun 15, 2008 1:42 pm
First name: Heath
Last Name: Blair
City: Visalia
does everyone radius their bridge plates or just plop them in and let them conform to the radius dish? ive only done one (.090"), but i did not radius it.
sweat the small stuff.
PostPosted: Sun Jun 15, 2008 1:46 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
I tried a thick bridge plate (about .160) with a tall/thick bridge and it seemed to work OK (the top seems very stable). The bass notes were more accentuated...which was kind of what I expected since I figured I added more mass than stiffness...
http://www.PeakeGuitars.com
PostPosted: Sun Jun 15, 2008 3:55 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I've seen many cracked & deteriorated plates in the last 30 + years.
Big repair job-not easy to do right!
thin ones go first!
I make mine of a .080 +.020 + .020 hardwoods with the grain 90 degrees to each other.
Never had a cracked one or a ripped apart one(caused by the string balls)
Also as the ladies say-size does matter! oops_sign
mine are just bigger than the bridge-not large like I've seen on some guitars !
Just my thoughts on the subject!
Mike [:Y:]
Mike Collins
PostPosted: Sun Jun 15, 2008 4:26 pm
Mike are you saying you "glue" them up ply style? That might solve most cracking issues, as well as radius sanding taking some stress off.
PostPosted: Sun Jun 15, 2008 7:25 pm
First name: Chuck
City: Houston
I really appreciate all the replies. I thickness sanded it to .90 give or take a hair. John Hall drew a Martin pre-war bracing pattern for me. The bridge plate is maple and it's 46 mm wide. The sitka spruce top is .105"
I also didn’t radius it. I just now glued it in with hide glue. Would you advise I take it out and radius it?
PostPosted: Sun Jun 15, 2008 9:27 pm
No you're fine. Press on.
PostPosted: Mon Jun 16, 2008 9:26 am
First name: Chuck
City: Houston
Thanks John
PostPosted: Wed Jun 18, 2008 12:53 pm
First name: Ron
Last Name: Y
Timely post. Can I use walnut off cuts for a bridge plate with the grain running the length (left to right once installed)? Thanks.
Ron M.
PostPosted: Wed Jun 18, 2008 2:44 pm
What's peoples views of adding as brass shim to the back of the bridge plate?
Formerly JJH
Users browsing this forum: UncleMikey and 19 guests
