It is currently Thu Sep 18, 2025 1:17 pm
Post new topic Reply to topic  [ 97 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Jun 26, 2008 3:01 pm
David,
This is very interesting to me. Thanks for posting it.
PostPosted: Thu Jun 26, 2008 4:40 pm
First name: Jim
Last Name: Kirby
David - Why is the back center strip needed? Do you have a sense that it is structural?
Jim
Jim Kirby
kirby@udel.edu
PostPosted: Thu Jun 26, 2008 6:51 pm
First name: David
Last Name: LaPlante
Yes Jim I think so.
The original has this and I'll include it in order to be as faithful as I can to the original design.
The cardboard has the same stiffness in all directions thus the usual extra strength one would have along the grain of the back is not there.
I think this is what was behind the thicker and stiffer back reinforcement strip.
PostPosted: Thu Jun 26, 2008 11:42 pm
First name: David
Last Name: LaPlante
Top bracing is now complete.
The unusual cut off braces (as far as I know) are unique on a Torres guitar.........these would make more sense if they were a later addition.
The rosette installed.
The first step in "free assembly" is to align and glue the neck to the top as well as the end block.
PostPosted: Fri Jun 27, 2008 5:54 am
First name: Jim
Last Name: Kirby
David LaPlante wrote:
Yes Jim I think so.
Aside from the question of historical accuracy, it looks like a very good candidate for an X-braced back, to pick up the extra stiffness along the back.
Jim
Jim Kirby
kirby@udel.edu
PostPosted: Fri Jun 27, 2008 2:00 pm
First name: David
Last Name: LaPlante
Continuing with the "free assembly process"
The sides are aligned with the penciled tracing of the pattern on the inside of the top and glued to the neck and end blocks.
No glue is used along the edges where the sides meet the top, glue blocks (peonies) are installed to attach it at this juncture.
PostPosted: Fri Jun 27, 2008 8:12 pm
First name: David
Last Name: LaPlante
Here is the rather stiff center support being glued that Jim Kirby and I were discussing. It's about twice as thick as a normal one and the grain is longitudinal so it adds a lot of support to the back.
PostPosted: Sat Jun 28, 2008 2:00 pm
First name: David
Last Name: LaPlante
One observation to share is that the more complete the structure gets, the closer it feels to being made of regular materials. I expect that it will feel and weigh what a typical guitar would.
The reinforcement strip shown previously has stiffened the back plate up nicely. Here is the bracing being glued.
I'm notching the bracing over the strip to maintain as much support as possible.
PostPosted: Sat Jun 28, 2008 3:15 pm
Thank you for the updates, this is a very informative thread!
PostPosted: Sat Jun 28, 2008 5:54 pm
Country: Romania
Funny that when I was reading the initial discussion on the back cedar strips, I was thinking that if I was to build a cardboard guitar I would use a pair of solid cedar strips (mimicking a 3 piece back) and notch the spruce bars over. Then i decided not to post it because well, it wasn't me building :)
Build log
PostPosted: Sat Jun 28, 2008 6:53 pm
First name: David
Last Name: LaPlante
Alex, according to Joan Pellise' there are actually three in the original. However, Joshua French observed that the outer two are later additions. I've just put the main center one in as I used a slightly heavier board. I also could see its shape in the photos.
PostPosted: Sat Jun 28, 2008 9:01 pm
First name: Jim
Last Name: Kirby
This is starting to get really compelling. I can't think of any vaguely interested person who wouldn't be astounded if you pulled one of these out to show to them. I know the original sounds good, and can't wait to see how your does. A similar one may be next on the list here.
Thanks for all the discussion of the back brace.
Jim Kirby
kirby@udel.edu
PostPosted: Sun Jun 29, 2008 12:41 pm
First name: David
Last Name: LaPlante
The linings are now in (kerfed Spruce) as well as the "long" rib blocks to support the harmonic bars.
The back is ready to be fitted and glued. The back braces will also get shorter "rib blocks".
PostPosted: Sun Jun 29, 2008 2:30 pm
This is quite exciting. :D
I'm looking forward to the finished results.
PostPosted: Sun Jun 29, 2008 10:00 pm
First name: Sen
Last Name: Goh
Country: Singapore
Hi David,
This is definitely getting more and more interesting and exciting.
I have one question regarding the stiffness of the sides.
(Before and after closing)
Would it be able to withstand the weight of the player's arm resting on the lower bout?
Is there any deformation of any sort?
Sen
Sen CL Goh
http://senguitar.blogspot.com
PostPosted: Mon Jun 30, 2008 10:59 am
First name: David
Last Name: LaPlante
No problem in that regard. I've used a somewhat thicker material for the rims than on the original. As a result, I've left out the later added reinforcements and have a nice resilient structure.
Here is the back being glued.
PostPosted: Mon Jun 30, 2008 12:20 pm
Ooooh, ^ that would make me a bit nervous!
Looking great David.
Many thanks!
PostPosted: Mon Jun 30, 2008 12:31 pm
David,
This is a fascinating project that I am really enjoying following and I will be interested to see how it plays and sounds when finished.
Is this one where a future repair could be "papering over the cracks"? Sorry . . . I couldn't resist that one.
PostPosted: Mon Jun 30, 2008 1:19 pm
Dave, this is the one that you just crumple up and toss in the recycle bin if you don't like the sound! :D
PostPosted: Mon Jun 30, 2008 2:03 pm
First name: David
Last Name: LaPlante
OK, Out of the clamps, flush trimmed (I went to the store and picked up a new Freud bit to get the cleanest cut I could) and cut for bindings.
A relatively new bit from LMI produced pretty clean results. I had to be careful to "back in" to the cut all the way around as the cardboard will tend to deflect and bunch up in front of the bit.
At this point, the less I try to fool with the surface the better. I've pre sanded my rosewood bindings and beside a little rounding over at the edge, I'll pretty much
have to live with the fit I get out of the gate. The top can be handled in the usual way, but the back and sides
will have to forego any scraping or sanding.
PostPosted: Tue Jul 01, 2008 8:08 pm
First name: David
Last Name: LaPlante
Back Bindings are now in.
The preliminary carving of the heel has been done plus the fret board and bridge are under way.
Next, the top binding and purflings go in.
PostPosted: Wed Jul 02, 2008 4:24 pm
Mike Collins wrote:
Dave ;
is that Brazilian poster board? oops_sign
No, Mike, it's obviously Manila. ;)
Interesting project, Dave. Strange....but interesting. I admire your sense of adventure! [:Y:]
Carlton Macksam
Muskegon, Michigan
PostPosted: Wed Jul 02, 2008 4:41 pm
Carlton!!! Great to see you here again!!!!
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
I can remember as a kid telling my dad that I could easily build a guitar. I remember having this image of a shoe box, with a wrapping paper roll stuck in one end and some strings across the whole thing. Now I know i was wrong to go with the wrapping paper tube. :D
Seriously, this is a fascinating thread. I can't believe how fast you work though. Sheesh. Something tells me this isn't your first rodeo.
Darrin
PostPosted: Thu Jul 03, 2008 12:17 pm
First name: David
Last Name: LaPlante
Here is the top binding in with the cloth tape wrapped to secure it as the glue (fish) dries.
Now trimmed flush with the surface of the top. As this point I can evaluate whether I got the plantilla right.
Detail of the binding and rosette.
Users browsing this forum: No registered users and 40 guests
