It is currently Wed Jul 23, 2025 4:48 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jul 17, 2008 10:01 pm
City: Duluth
State: MN
Howard Klepper wrote:
I thought he was talking about standing the rim set upright, tail block to the table, and putting 180# on top of the head block end.
Yep, that's what I meant. Can it be done and still keep the sides *relatively normal* thickness and weight overall?
Dennis
Dennis Leahy
Duluth, MN, USA
7th Sense Multimedia
PostPosted: Thu Jul 17, 2008 10:08 pm
You guys doing laminated sides: Are you doing your own resawing and cutting your sides thinner right off the bat, or are you thinning down sides of a "normal" thickness from suppliers, or are you purchasing thinner sides, or what?
PostPosted: Thu Jul 17, 2008 11:25 pm
City: Duluth
State: MN
ToddStock wrote:
Well that is a little tougher. Sounds like a job for Photoshop.
And I've never met a 180 lb ballerina, or at least one that was not in drag...they all seem to be about 105 dripping wet.
But, she told me she was "Amanda." Oh, wait a cotton pickin' minute! Maybe he was saying "I am a man, DUH!" :oops:
Sure could pirouette though. But I digress...
So, you're saying I'll need 3-ply, with titanium as the middle ply?
Dennis
Dennis Leahy
Duluth, MN, USA
PostPosted: Fri Jul 18, 2008 7:29 am
Well, maybe fifty-four ply. Using maple veneer, I'd guess that when you had enough layers built up to prevent deflection when the ribs were on an end block, you could dispense with the lining. I've seen this (well, fewer than 54) on thinline AE s, where the plates were glued right to the thick sides. I'd sure hate to have to hand-sand a stack like that on a dish or flat plate.
Dan
Dan
http://www.acme-archtops.com
PostPosted: Fri Jul 18, 2008 7:58 am
Brock Poling wrote:
Have you tried using solid or capped linings? I find that also makes a big difference. I am just doing 2 sides (not 3) but I find that the rims are very stiff alone but once the capped linings go in there is absolutely no moving them. They are rock solid. 0 flexing.
I agree with you on the weight. Mahogany and koa doubles still seem to be very light, but rosewoods, ebonies, etc, tend to get a little heavy. I have been working on trying to find a way to keep the epoxy from seeping though (to reduce the sanding necessary) so I can thin out the sides further and reduce the weight.
Actually for the 2 builds I did with laminated sides I used laminated solid linings (5 x .045" strips of mahogany/bloodwood and mahogany/spruce). Doesn't get stiffer than that… It's a lot of work though, as I had to build the forms to laminate the linings, and gluing solid linings onto compound curves is a struggle. Again those are spec guitars.
After all this, I'm not sure it's worth the time and effort. I'm well advanced on a 2nd build with side doublers and kerfed linings, and I think I settled on this method for now. As part of the system I tend to brace my backs on the heavy side, and cap the braces and graft with a hardwood laminate.
Veneer is widely available in roughly .023" and .040" thicknesses. I resaw mine when I can, or when I want specific tonewoods. The outer layer is just a side set taken thinner than the usual .070"/.085" range.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri Jul 18, 2008 8:49 am
Online
I think to best withstand the forces of weight on the neck block when standing upright a brace running across the waist would be best. That and no flat point at the neck joint area. I have put a cinder block on the rims with very little deflection after installing solid linings to double sides just to see if I could. Most of that movement was at the waist.
For solid linings, I have been utilizing the double side glue-up procedure. I bend 3 sides of spanish cedar at about .085-.09 and glue those 3 together over the 2 double sides. They all lock together and then I use that 3 ply cedar lining sandwich as the caul for the second pair of double sides. Once that is done I rip 4 pieces off of the sandwich for perfect fitting and ultra stiff linings. You have to rip them well oversize to account for the taper and then sand in the correct shape. A 4 1/2" side will take care of most styles. I built a jig too to rout in perfectly tight side braces that extend all the way through the linings with no gaps. It has worked very well so far and is so quick and easy to install, it is already perfectly mated to the side as they were created (glued up) together. It assumes your double side jig registers against the outside of the side though, not the inside. It removes having to offset anything, you can use any lay up you want.
Burton
Brookline, MA.
PostPosted: Fri Jul 18, 2008 12:16 pm
Online
Todd,
All of the reverse kerf linings I have seen are rectangular up to the cap where it is then rounded over. With the solid linings, you can put a very steep traingular profile into them. That does a lot to offset the loss in mass by kerfing the reverse kerf linings. Not that it matters too much, it is such a small amount of mass. I do notice a much larger difference in stiffness between them though. I made some reverse kerf linings for a couple and when I switched over to the solid I was really surprised.
Burton
Brookline, MA.
PostPosted: Fri Jul 18, 2008 2:27 pm
This is an experimental thin body archtop that I built for myself. Look inside, and there are no liners! The liners run the full depth of the sides, with a curly maple veneer over them on the inside. Stiff. We're talking Viagra-like. Weighs a little more, and while the sides are extremely crack resistant (fully bias-grain lined), I do worry about repairs if, say, it got smacked into the corner of a table.
PostPosted: Fri Jul 18, 2008 3:10 pm
I have been building my double sides with the grain of the inner lamination running perpendicular to that of the outside. Another idea I've been experimenting with is laminating fiber on the inside instead of wood. The first approach has produced good results and a stiff rim. I'm not sure yet about the latter though.
Don Sharp
Got Brazilian?
http://www.sharpguitars.com
PostPosted: Fri Jul 18, 2008 5:37 pm
Don, you're edging toward plywood! Seriously, has anyone experienced the cupping or bowing I would expect from a two-piece lamination, grain parallel? Especially using two disparate species? Cupping is not a problem with three-ply, the middle ply crossing. So, what are the objections to three-ply, since we're talking extremely stable, stiff as you'd want, and crack-resistant. Oh, and not, repeat NOT a tone hinderance (I have my sources on this).
Howard, the lined liner effect is the cat's patootie. Torsion boxes, yes! And with soundholes, perhaps offset, they could be tunable. Could there be a built-in reverb?
Dan
Dan
PostPosted: Fri Jul 18, 2008 5:47 pm
Speaking strictly about laminated sides, my experience is that turning the middle layer to 90 degrees does affect tap tone of the rim assembly. It kills it on mine. Keeping the layers parallel has no negative effect, instead it actually provides a really strong tap tone. Surprisingly, the laminated rims are more resonant than a solid wood rim set. I also had more problems with warping when the layers were not parallel. Different strokes...
PostPosted: Fri Jul 18, 2008 7:15 pm
REALLY!!! Where are you getting .04" veneer?
That would make my life much easier.
PostPosted: Fri Jul 18, 2008 7:20 pm
Barry, I just ran over to the shop and tapped on everything in sight! The single BRW was pitched a little higher and had a slight "bong", and the three-ply maple was pitched a bit lower, but didn't seem to suffer any attenuation. These were both bent sides for a Rodriguez model classical. The five-ply three-inch-wide archtop side was pitched higher than either, and still seemed to not fall flat when tapped. One hardly knows where to hold a side for tapping; I found the friendliest spot on one edge where the part balanced, and then hunted around for a responsive tapping spot, but I gotta ask, does it matter? We're going to glue linings and then top and back plates to these things, and they're not being directly excited by the strings, and.....
OK, of course, everything on a guitar does matter. I just wish there was a way to build the same guitar twice, with just the one difference, and then A/B the snickers out of them.
Dan
Dan
PostPosted: Fri Jul 18, 2008 10:10 pm
http://www.wood-veneers.com/table-1.htm
Laurent Brondel
PostPosted: Sat Jul 19, 2008 1:27 am
laurent wrote:
Hey, this guy is right near me. He works out of his garage, basically. He sells some amazing stuff.
PostPosted: Sat Jul 19, 2008 7:53 am
Why would it be any worse than a solid piece (assuming the same species for both pieces)? I suppose if the plies were different thicknesses you could have problems.
PostPosted: Sat Jul 19, 2008 6:10 pm
Andy
Well, you may have seen a thin slice of wood curl away from the side you spread glue on (the wet side) as the cells on that face absorb water. I see it all the time when face-gluing veneer, admittedly thin and flexible stuff. It just seems to me that two different species, say a rosewood and a cypress, would curl different amounts and at different rates, and then, when clamped together, dry at different speeds while trying to exert their different rates of stiffness against each other, in other words I'd expect one to overpower the other.
Perhaps if one is gluing two pre-bent sides to each other the curves help the wood resist swelling and cupping, and if the parts are on the order of a mm thick they are even more resistant?
Yes, if you work with layers of different thicknesses things can get tricky - this is why the best quality plywoods tend to be built of uniform veneer thicknesses, with a balanced though odd number of plies in the layup. But then we're back to crossing plies, which tend to resist movement.
When I first started doing what I do I thought "Why not laminate an archtop plate with ALL the plies running parallel? Won't that more closely resemble natural lumber than crossplying?"
The first effort was such a flop I abandoned that approach. The three-ply spruce stack lost it's arch almost completely in a couple of hours, after curing in the mold overnight, and then went on to potato-chip spectacularly over the next couple of days. I had started with spruce 0.050" thick, but flat, not pre-shaped.
So there is the reason I was asking - my experiences in a parallel universe were not encouraging.
Dan
Dan
PostPosted: Tue Jul 22, 2008 6:14 pm
First name: Erik
Last Name: Hauri
State: Maryland
Impregnating wood with certain glues may make it stiffer, but then we are talking about making a composite of wood and another material, which could as well result from impregnating a solid as from laminating.
Indeed....this must be part and parcel of laminating sides, especially using epoxy.
How many folks are using wood glue vs epoxy?
The member formerly known as erikbojerik....
Users browsing this forum: Burton LeGeyt and 28 guests
