It is currently Wed Jul 23, 2025 4:36 pm
 Post subject: stringing up a classical
PostPosted: Tue Jul 22, 2008 7:30 pm
Can anybody show me the proper way to string up a classical bridge with 6 holes?
It would also be nice to see the difference between a 6 hole, a 12 hole, and an 18 hole stringing method.
I have searched the web to find a "standard" method, but there seems to be several ways of doing it??
Which method works best and looks best too?
Please consider this "this idiot's guide to stringing a classical" :D :D
PostPosted: Tue Jul 22, 2008 8:14 pm
First name: David
Last Name: LaPlante
For six hole:
Ken, the wound strings ends that are completely wound tight go through the bridge in this method.
Low E,A and D strings through the hole leaving a couple inches at the back of the bridge.
With the guitar shown as in picture, the extra at the back of the bridge is brought around clockwise under the string through the front and back around under the loop and behind the tie block. Holding the end under the loop, pull the string in front of the brige tight to catch the end under the loop and against the block.
G,B and High E loop the end around counter clockwise under the string at the front of the bridge and wind over and under the loop created (at least 3 times for the G, 4 times for the B and 5 times for the E) and while holding the loops pull tight from the front.
If done properly all your string ends should be pointed toward the bass side of the guitar.
Twist the string ends at the rollers so they loop over and under the string as it is wound tight.
PostPosted: Tue Jul 22, 2008 11:24 pm
Thanks David!
From all of the descriptions I have seen ont he net, yours makes more sense than any of the others. Much appreciated!
PostPosted: Tue Jul 22, 2008 11:36 pm
Here's a good visual tutorial on David Schramm's website demonstrating a method described by John Gilbert.
http://www.schrammguitars.com/tutorial.html
One of the things I always do is take a match and burn the top 3 string ends until there is a ball about twice the size of the string diameter. This helps keep the string from slipping through the bridge.
PostPosted: Wed Jul 23, 2008 10:05 am
I second the Schramm posted method, for neatness and efficiency. I have been using that now for about a year on my 6 hole guitars. However, David's method is the traditional standard, and works very well. Just make sure you put at least 3 wraps on the high E string, and make sure the last tuck is over the corner of the tie block, on the face nearest the tail. Melting a little ball on the end of the string is good insurance to keep the knot from slipping, even with three wraps. Depending on the string, they can still slip, without the ball, and make a nice mark on the face of the guitar.
PostPosted: Wed Jul 23, 2008 4:02 pm
First name: David
Last Name: LaPlante
It looks like Dave Schramm's method for the treble strings is quite similar to the bass string method that I've described with the melted "ball" end added to keep the treble strings in place.
For my own guitars, I've moved to the 18 hole design. Not the easiest to make but certainly the most likely to eliminate those nasty string dents that Waddy describes.
My only problem with the Schramm method is that you can't take the strings off at the bridge while leaving them on at the peg head end. Often in building a guitar I'll do this to go at a final rubbing out of the top once the finish has hardened......and considering how I hate new strings and their need to stretch, I like to leave the same set on through the adjustment and final tweaking of the action and finish.
http://www.guitarsbydavidlaplante.com/
PostPosted: Wed Jul 23, 2008 5:14 pm
I was doing that with my 18 hole bridge, until I had one that I put back on slip. I don't know what caused it, but the E string slipped right out of the tie. Fortunately the 18 hole bridge slowed down the whiplash to a point where it did not do any damage. The funny thing, well, peculiar, was that it didn't slip immediately. I now melt the ball on the treble strings for the 18 hole bridge.
PostPosted: Wed Jul 23, 2008 5:52 pm
Thanks for the info guys!
My flamenco is almost ready to string up (after a polishing) so I'll be trying out your methods soon. I guess you all have also seen that there are several ways to string one up, and that is what was confusing me. I'll do my best to make it all work, and remember to make the string balls too.
Thanks again!
PostPosted: Thu Jul 24, 2008 1:03 pm
I haven't tried these before, however, I like the simplicity of the product. I like simple... :D
www.bridgebonebeads.com
There was a discussion over at the delcamp classical guitar site last April about them discussing the yay's and neigh's.
Ray
Guitar Building = Continuous Improvement Process
PostPosted: Thu Jul 24, 2008 1:39 pm
First name: David
Last Name: LaPlante
This sort of thing can be a good solution to the problem of having had to lower the action on a guitar to the point of the string not breaking over the bridge saddle sufficiently.
The traditional stringing methods loop the string under itself pulling it upwards and reducing the break over the saddle.
Luca Waldner has also developed some little metal plates which enable the same sort of thing.
PostPosted: Mon Jul 28, 2008 9:06 pm
First name: David
Last Name: LaPlante
Here's a bit of a different take on the 18 hole bridge. The single hole row is at the top rather than at the bottom. Works a bit differently than the standard.
PostPosted: Tue Jul 29, 2008 9:15 am
I like how it positions the string ends in the tie. I also like the bone plate on the tie-block. Must require a deep slot between the saddle and and tie-block.
PostPosted: Tue Jul 29, 2008 12:27 pm
if all else fails, you know they make nylon strings with ball ends right? [uncle]
my preffered method is when the left over of the string at the bridge proceeds tucked under then next string knot, looks snug and tidy.
Users browsing this forum: Ken Lewis and 22 guests
cron
