It is currently Wed Jul 23, 2025 5:44 am
 Post subject: binding bit
PostPosted: Thu Aug 21, 2008 1:33 pm
what bit is best to use for routing the binding channel. i am doing it with a lam trim router that has an edge guide for curves and such. i am gonna just make a donut for the radius and was wondering what bit will get least tear out. spiral cut down?
 Post subject: Re: binding bit
PostPosted: Thu Aug 21, 2008 2:54 pm
In my somewhat limited experience, a spiral down cut works fine.
PostPosted: Thu Aug 21, 2008 3:51 pm
Same here.
What type of edge guide do you have, is it just a single point or bearing that registers off the sides? It is far easier to keep the trimmer parallel to the sides if you have two points (over / under), or some other dedicated binding jig.
PostPosted: Thu Aug 21, 2008 8:00 pm
First name: Greg
Last Name: Harrington
You are right. Spiral down. It cuts down on the wood and leaves a cleaner, less fuzzy edge. Upcut is good for saddle slots as it clears the waste up out of the slot (a bit any way).
But with a lam trimmer I use a rebate bit with a bearing to set the horizontal depth. One bearing to cut the shallower purfling slot then with a larger bearing and
more vertical depth, the binding slot/"shelf"
Greg
Users browsing this forum: Bob_H, PGrubb and 22 guests
