It is currently Mon Jul 21, 2025 7:54 pm
PostPosted: Sun Aug 24, 2008 4:38 pm
Is there a simple method to transfer the brace layout from a plan to the top?
PostPosted: Sun Aug 24, 2008 5:06 pm
Not sure if you'd call it simple, but it works for me. I just make cut outs on the plan at the brace junctions and at brace ends, also at the centre line at head and tail. Just overlay the plan onto the top and mark with a pencil. I never use commercial plans, but if you didn't want to cut holes in the original just make a tracing.
In true 'Blue Peter' mode (the Brits will understand) here's one I made earlier.
PostPosted: Sun Aug 24, 2008 5:30 pm
First name: Kirby
Colin curiosity has the better of me what is true 'Blue Peter' mode?
If I get a pfft for an answer I realize I earned/deserve it.
Those words in conjunction over here in the colonies Carry quite a different connotation.
"It's a Tone Faerie thing"
PostPosted: Sun Aug 24, 2008 6:00 pm
I use the same method as Colin - for transferring bracing locations from plans to tops that is......... :D
PostPosted: Sun Aug 24, 2008 6:20 pm
Well, since on my plans the top brace layout is drawn as looking through the top I have to flip the layout over and since I plan on making several of these I guess I should make a template from polycarb or plexi. I do have some 18" X 24" C THRU graphic sheets that probably would work well and are easier to cut then plexi.
PostPosted: Mon Aug 25, 2008 4:30 am
Blue Peter is the iconic British Childrens' television programme. It has been running for the best part of 50 years, and every adult under 60 can remember the names of the presenters from their era. Over the years they have shown children how to make things from everyday objects, and of course under the counter they always had one they'd 'made earlier'.
By the way it was Valerie Singleton, Peter Purves and John Noakes for me.
PostPosted: Mon Aug 25, 2008 7:12 am
ToddStock wrote:
Mmm...always thought a Blue Peter was the 'Ready to Sail' signal flag...learn something new every day.
That's right the Blue Peter logo for the show is a galleon with the blue Peter flying. To be given a 'Blue Peter' badge by the programme is an honoured accolade, you'll still see British experts, scientists, historians etc wearing their Blue Peter badge with pride, it's better than a Knighthood! A gold Blue Peter badge is probably the highest honour than anyone in the UK can receive. :roll:
PostPosted: Mon Aug 25, 2008 7:14 am
Todd,
It is, and that is what the programme was named after.
One highlight was when they showed you how to make Tracy Island from Thunderbirds from stuff you would normally throw away. 1001 things to do with sticky backed plastic . . . :D
PostPosted: Mon Aug 25, 2008 8:53 am
I plot my brace plans on 8mil transparent mylar, then punch a small hole in each brace edge intersection. I lay the plan on the top and line up the centerline and sound hole location. I use the holes to transfer a pencil dot to the top. I then remove the mylar plan and connect the dots.
PostPosted: Mon Aug 25, 2008 9:19 am
I have a center line and the center lines of all of the braces penciled beyond the guitar's outline. I lay the top on the plan, lining up the center line and the soundhole, line up a straight edge to the penciled marks and mark the top.
Ken Whisler, guitarist and luthier
PostPosted: Mon Aug 25, 2008 9:26 am
For any guitar design I plan on building more than a few of of, I build a simple template from acrylic that registers with the soundhole and gives me perfect placement of the x-brace and upper transverse brace. The rest are very easily registered off there with simple acrylic or even MDF spacers/templates. I haven't taken a pencil to a soundboard for marking brace layout in a long time.
Richard
http://www.guitarmaker.com
PostPosted: Tue Aug 26, 2008 3:01 pm
I have a Plexiglass Body Half with the brace centers marked and a small hole bored at the end of each brace. I mark with a pencil, then lay the braces between the dots. I mark across each dot with a straightedge laid out between the dots for that brace, and put a cross line at the end of the brace at each end.
PostPosted: Wed Aug 27, 2008 6:35 pm
Here's what I came up with. I used the triangle cut outs and 1/4" holes which I saw on LMI's plexi templates. Thanks for the help guys.
Users browsing this forum: dofthesea, zmp2 and 36 guests
