It is currently Sun Apr 19, 2026 6:26 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
PostPosted: Sat Aug 16, 2008 11:33 am
First name: Heath
Last Name: Blair
City: Visalia
im not sure if anyone has mentioned this yet, but i made my go bar deck to be adjustable in height. i know others have done the same. all of my go bars are 24" in length. i simply adjust the height of the deck for the appropriate operation. the height is adjustable via 4 pieces of all-thread, nuts and washers. hope the picture explains it well enough.
sweat the small stuff.
PostPosted: Sat Aug 16, 2008 12:15 pm
Perhaps someone else has already thought of this, but it would be really cool to have quick-release nuts for this, like those found on some drill press depth adjustments, where you push a button in the middle of the nut, and can then slide it up and down. It'd also be cool just to say that you have quick-release nuts.
PostPosted: Sat Aug 16, 2008 12:53 pm
First name: Heath
Last Name: Blair
City: Visalia
laughing6-hehe laughing6-hehe laughing6-hehe
PostPosted: Sat Aug 16, 2008 1:07 pm
This version doesn't use such "quick-release nuts" (!), but it is a way to adjust the deck easily. I used two pipe-clamp parts for each corner and have notched out the corners. It works for me!
Kathy
Kathy Matsushita
San Jose, CA USA
http://theamateurluthier.com
Facebook: https://www.facebook.com/kathy.matsushita
PostPosted: Sat Aug 16, 2008 1:08 pm
Brilliant, Kathy! I love it.
Todd, I haven't had luck finding the motorized deck, but sure sounds cool.
PostPosted: Sat Aug 16, 2008 1:26 pm
I didn't actually come up with this idea myself — it came from an Internet friend, Mark Frazier — he did it somewhat differently, using only one pipe-clamp part underneath an adjustable bottom deck, which would work well, also.
Couple this with Hesh's great pull-out TV swivel idea (which I used this summer), and you have a very, very easy to use go-bar deck!!! (I did a little video on this because I was so tickled with how it came out: http://home.comcast.net/~kathymatsushita/moreprojects/htmlpages/atc12.html)
(The video is at the bottom of the page.)
Kathy
Kathy Matsushita
San Jose, CA USA
PostPosted: Sat Aug 16, 2008 2:10 pm
I've posted this before, but checkout how George Lowden does it. It's a bicycle innertube with fabric straps stapled to plywood.
PostPosted: Sat Aug 16, 2008 3:10 pm
Here's me gluing the back with go bars, well, sort of.
Also, the support bars have fixed inner blocks, so if I wanted to adjust the height, I could add a slotted spacer by loosening the wing nut and slipping it in on each rod. What I do, however, is have a fixed height and add a spacer to the go-bars when I'm gluing at deck level. You can see the spacers in the top of the bars in this picture.
level.
PostPosted: Wed Aug 27, 2008 11:17 pm
Anybody use go bar deck to glue on the bridge?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Wed Aug 27, 2008 11:20 pm
Kathy where do you get those fittings where the pipe goes into the plywood on the base and on top?
Rich Smith
Issaquah, WA
PostPosted: Thu Aug 28, 2008 8:33 am
I just get those pipe clamps and only use the little end part (not the handle part) — find the cheaper pipe clamps and it won't be as expensive. You need 2 per corner, so 8 total. You just notch the corner of the deck to accommodate the clamp part.
Kathy
Kathy Matsushita
San Jose, CA USA
PostPosted: Thu Aug 28, 2008 9:38 am
Kathy
Nice video Kathy! [:Y:]
PostPosted: Thu Aug 28, 2008 12:25 pm
Very nice video, Kathy.
PostPosted: Thu Aug 28, 2008 12:50 pm
Heath, I did the same thing many moons ago but I use 3/4" althread so I could make the deck 40" tall and very rigid. One of the best fixture re-works I have done. it is not as quick as pipe clamps to change heights but it only takes a min. or so. I also doubled up the 3/4" birch play decks to 2 sheets (1.5 total) to eliminate as much deflection as possible. I mounted a large heavy duty lazy susan on the bottom and attached to a dedicated 36x36 bench. I have (4) 3/8" dia holes drilled thru the lower deck 90 degrees apart and one in the bench top and use a 3/8 dowel as a locking pin while riging bars. I reall love this setup .
PostPosted: Thu Aug 28, 2008 4:56 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I do the same as Heath.This works really well for me to be able to adjust the height.It seems a lot more versatile this way.
James W B
James W Bolan
Nashville Tennessee
PostPosted: Thu Aug 28, 2008 5:00 pm
Is it just me or does it look like there is a guy's head being squeezed out of this press......
PostPosted: Thu Aug 28, 2008 5:36 pm
Anybody ever consider just having two different length fiberglass go bars on hand? Works for me.
PostPosted: Sun Oct 19, 2008 12:47 am
http://www.tvshelves.com/images/225_2.gif
Is this the swivel used on the go bar deck ??
thanks Ange
PostPosted: Sun Oct 19, 2008 7:57 am
I don't use two different sizes of go bar rods, but do have two different sizes of 1/2" threaded rod for the go bar deck. Since I keep the deck broken down when not in use, I just pick the shorter set when setting up to glue braces to the plates, or the longer set when gluing the top and back plates to the sides.
