It is currently Mon Jul 21, 2025 9:20 am
PostPosted: Sat Sep 20, 2008 2:31 pm
I'm starting my first parlor and I'm wondering if the thickness of the top, side and/or back should be thinner than say an OM. The bracing will obviously be lighter but should the thickness of the plates also change? Thanks.
PostPosted: Sat Sep 20, 2008 2:38 pm
Sure you can go thinner on the plates provided that the wood that you are using will provide the desired stiffness at a given thinner thickness. I know that this answer is not much help but many builders do not build to a spec instead individually thicknessing the plates toward a desired deflection measurement.
What woods are you using for the back and sides and the top?
PostPosted: Sat Sep 20, 2008 3:47 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
SS.
I make a
Martin size from the 1850's and for steel strings with a well cut top(stiff-1/4ed well-lite in weight) mine are 2.2mm in the center to 1.8mm on the edges-they sound wonderful!!!!!!
If you like i can send you a template of the guitar size.
mike :)
Mike Collins
PostPosted: Sat Sep 20, 2008 5:25 pm
I haven't gone as small as a parlour yet, but I always go thinner for the top and back as the body width gets smaller.
Mike, what is the size of the Martin body that you are working with? I would be interested in a template if you're offering.
David White, Toronto
PostPosted: Sat Sep 20, 2008 5:32 pm
Mike: First I'd love a template if you don't mind. Second, what you use for the top is pretty consistent from something I found in the MIMF archives--someone posted that he thins his tops to .095" which, if my math is right, is pretty close to your tops. Do you x-brace your parlors? I've seen some drawings where they use ladder bracing. What do you do with your backs and sides? I'm using bubinga, if that makes a difference.
PostPosted: Sat Sep 20, 2008 9:18 pm
The last size 2 I built really sounded great. It was tough to let go. Nice stiff sitka top cut in the 70's I wound up a little thicker than Mike but not by much.
http://www.thepodium.com/p-16608-kenned ... arlor.aspx
These are the specs:
Sitka/Mahogany 24.9 scale length 12 fret.
Top: 0.094 center, thinned to 0.085 at the edges of lower bout
Sides 0.078
Back 0.095
Bridge plate (Maple) 0.085 1 1/4" wide
X Brace 0.250 wide 0.050 high at the X
Soundhole 3.5
Terry
PostPosted: Sun Sep 21, 2008 7:24 am
Thanks Terry. That's a beautiful guitar, by the way.
PostPosted: Sun Sep 21, 2008 2:09 pm
Last Name: Collins
City: Argyle
State: New York
I think is was a 2 1/2 size-signed by the real C.F. Martin!
beautiful guitar!
I use X bracing for a steel-fan for a nylon-no latter-the martin was a fan so to speak.
Dr & SS -the sides were around .075 -but they varied allot!
If you pm me I'll send all the specs also.
Also I'll send you pixs of this beauty !!
mike
Mike Collins
Users browsing this forum: JimWomack and 15 guests
