It is currently Thu Sep 18, 2025 10:33 pm
 Post subject: neck wood
PostPosted: Wed Oct 22, 2008 7:49 pm
First name: Jeff
Last Name: Hewitt
Zip/Postal Code: 37312
I know most likely what the answer will be.....but I would like to know if any of you would or do use flat sawn lumber in neck construction? I'm thinking of making a neck from flat sawn Honduras Mahogany along with carbon fiber for reinforcement. What would you do?
Jeff
 Post subject: Re: neck wood
PostPosted: Wed Oct 22, 2008 8:06 pm
I think it has been pretty much been decided that flatsawn mahogany is as strong and stable as quartersawn. Throw in some CF and you'll be fine. Fender has used flatsawn maple in their necks since day one. Ervin S. had an interesting article in GAL sometime back showing his testing results with flatsawn vs quartersawn spruce. Some flatsawn pieces were actually stronger.
In Markham,Virginia
PostPosted: Wed Oct 22, 2008 8:56 pm
Laminate and it will become quartersawn. Magic!
PostPosted: Wed Oct 22, 2008 11:29 pm
I do exactly what Howard says. I laminate flat sawn and it's then quartered. The trouble is, it's even getting hard to find straight flat sawn wood these days.
PostPosted: Thu Oct 23, 2008 1:52 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Woods from the Mahogany & Cedar families are some of the most stable woods there are if used when dry.
Add Carbon Fiber & it's an incredible neck!
Do you mean Epoxy Graphite?
Mike Collins
PostPosted: Thu Oct 23, 2008 3:37 pm
First name: Jeff
Last Name: Hewitt
Stew mac carbon rods.
PostPosted: Sat Oct 25, 2008 9:59 am
And possibly stronger too. I always laminate flat sawn necks.
PostPosted: Sat Oct 25, 2008 10:34 am
First name: Chuck
Last Name: Gilbert
I also laminate flatsawn for my necks using a method similar to what our friend John Mayes shows in his video. Roger Siminoff (from "The Luthier's Handbook") has also done deflection tests showing flatsawn boards to actually be stronger than quartersawn.
Chuck
"To live a creative life, we must lose our fear of being wrong"
- Joseph Chilton Pearce
