It is currently Thu Sep 18, 2025 10:33 pm
PostPosted: Thu Oct 23, 2008 8:13 pm
I am thinking about building a baritone with a figured redwood top. I'm pretty sure that would be a disaster, so I want to make it more tough/strong/durable. Rather than going with Nomex, what if I just double it right up to Lutz? I figure I could put a light coat of epoxy on both sides, slap them together and then thickness sand to my deflection value. I'll leave enough redwood top on so I don't sand through, keep it light, etc. Does any one have any knowledge or warning or encouragement for me?
Thanks!
PostPosted: Thu Oct 23, 2008 11:35 pm
SteveS wrote:
...... Does any one have any knowledge or warning or encouragement for me?.....
I think its a good idea to laminate Curly redwood tops.
I do a "semi-double" top on all my curly tops and it works great. Laminated tops normally get a bit stiffer from lamination so I go a bit thiner.
PostPosted: Fri Oct 24, 2008 9:46 am
Those are beautiful guitars Peter. I remember you had quite a method of trimming and hole cutting for those. I'm wondering if all that was necessary. Rather than making it a little thinner, I would thin it to a predetermined deflection under load and use it if it was light enough, but I'm not sure what light enough is right now.
guess I better weigh my next several tops.
Does anyone have a target weight for tops. I have never weighed mine. oops_sign
PostPosted: Sat Oct 25, 2008 2:23 am
Is Peter the only one who has done this?
PostPosted: Sat Oct 25, 2008 7:06 am
Steve buddy all I have is encouragement for you my friend!
Peter - beautiful guitar!! [:Y:] [clap] [clap] [clap] [clap] [clap] [clap]
PostPosted: Sat Oct 25, 2008 3:08 pm
Steve, I saw a couple of curly redwood topped guitars that had major bellying on the bridge area. One of them from a top builder in the East Coast. That's the reason I came up with the "semi-double" tops which are used only with Curly Redwood tops or other figured soundboards. Not only does it reinforces the top it also stiffens it which IMO makes it a better sounding guitar than a regular curly redwood top. I do use a proprietary design that reinforces the top while removing weight....
It is a good idea to think ahead to prevent problems in the future.
PostPosted: Sat Oct 25, 2008 7:55 pm
peterm wrote:
........ I do use a proprietary design that reinforces the top while removing weight.... .....
Looks like I'll be working on my proprietary method. bliss
I'll let you all know what it is, when I know it works. [:Y:]
PostPosted: Sat Oct 25, 2008 7:56 pm
Thanks, I need it!
Hesh wrote:
....Peter - beautiful guitar!! [:Y:] [clap] [clap] [clap] [clap] [clap] [clap]
Yes!
