It is currently Sun Apr 19, 2026 1:22 pm
PostPosted: Sat Nov 08, 2008 9:41 pm
Does anyone have a good way to radius end and tail blocks?
What is the radius on a Martin? They all seem to be the same.
Steve Brown
PostPosted: Sat Nov 08, 2008 11:10 pm
First name: Heath
Last Name: Blair
City: Visalia
im assuming you are speaking of getting the radius on the side that will be glued to the ribs? if so, im sure there are other and probably better ways, but i just rough it out with a block plane or sander of some sort, then i stick some sandpaper in my outside mold at either the head or tail block location and slide the block across the mold until it fits the appropriate radius. make sense? you just have to make sure you keep everything square.
sweat the small stuff.
PostPosted: Sun Nov 09, 2008 12:09 am
how about something like this:
PostPosted: Sun Nov 09, 2008 8:25 am
First name: Pete
Last Name: Liccardello
City: Eden Prairie
State: Minnesota
Great idea John. Using a white board and taking digital photos is really a quick way to show a design or relay an idea!
Peter
PostPosted: Sun Nov 09, 2008 10:21 am
Stewmac fret board sanding block works well--jusy need to figure which radius you need.
PostPosted: Sun Nov 09, 2008 1:01 pm
Here's a commonly used jig that has proved very reliable for me. I've used it for about 4 years. I learned about it at the C Fox course. I seldom need to do any cleanup after I radius.
Terry
These users thanked the author Terence Kennedy for the post: Pmaj7 (Wed Dec 09, 2015 1:58 pm)
Users browsing this forum: Chris Pile and 25 guests
