It is currently Thu Sep 18, 2025 7:03 am
PostPosted: Tue Nov 11, 2008 4:47 pm
Hi there guys. I've received my first electric commission this week, and it's got me thinking about adding binding to an electric guitar.
"Easy!" you might say, "they're planks" :D The one I'm making will have a forearm contour though - can anyone think of a way to bind round that?! I have a hard enough time getting tight joints on a heavily arched back!
Below you can see a bound Anderson (well, a pile of them), all with bound contours, though I've got a feeling it's a faux, painted on binding.
PostPosted: Tue Nov 11, 2008 5:04 pm
How about this: a binding machine like the one Chris P. just built but with the following characteristics:
Smallest router diameter you can find
Longest binding bit shaft you can find (possibly use a 1/2" straight bit with a bearing follower like on Chris's machine
A Shoe or Doughnut that's tall enough so that when you're at the deepest point of the forearm relief no other parts of the fixture (or jig or whatever the hell it is) is hitting the top of the body
I think that would do it.
PostPosted: Tue Nov 11, 2008 6:03 pm
I suppose I should have been more clear - it's not the route I'm worried about! Its bending (or cutting) the binding to fit in there.
PostPosted: Tue Nov 11, 2008 6:07 pm
Those arent bound at all .... thats the curly maple top left natural, ala PRS, while the top has been tinted blue. The top has small blind cut slits inside the armrest curve area that allows them to bend it into shape even though its about 1/4 inch thick.
PostPosted: Tue Nov 11, 2008 6:14 pm
Again, I understand that :)
Just wondering if there is a way to do it with wood though?
PostPosted: Wed Nov 12, 2008 5:58 am
First name: Martin
Last Name: Edwards
depends on the top contour.
if the contour is a sharp corner, then use two pieces of binding and bevel the joint (all be it a LONG bevel)
if the contour is more gradual then binding SHOULD be able to be bent in both axes. you'll need a LOT of STRONG tape to hold it as the glue dries, but I'd certainly go for it.....
practice on the offcut from the body blank.
PostPosted: Wed Nov 12, 2008 8:05 am
I think you will have an issue at the bottom of the armrest curve .... the wood binding will be leaning outwards by the time you get it there, and you wont be able to pull it in with tape without causing a gap on the bottom edge, if at all. Plastic .. OK, but you will need to heat it a bit.
PostPosted: Wed Nov 12, 2008 10:58 am
I'm with Tony. I don't see being able to do it with wood (unless it's faux). Doesn't mean you shouldn't fire up the iron and try though!
PostPosted: Wed Nov 12, 2008 12:26 pm
Making the binding square first might help... What I mean is: Thin(.060-.120) binding that is tall tends to only bend front to back (or side to side). It does not bend well up and down against the height. But on the other hand, if you started out with a square wood binding it is capable of bending up and down as well as side to side. You will more likely have better results starting with that shape. Once glued in place, you could use a flush trim bit to remove the excess width of the binding that overhangs the original route. just a thought.
Joe
Joe
PostPosted: Wed Nov 12, 2008 2:56 pm
I see where you are going with that Joe .. but you still will be limited to relatively thin binding .. much more than .100 wont bend all that well on the curve.
besides - unless its really thin, like .040, its not going around the horns anyway. Thats why its done the way it is unless its plastic.
Users browsing this forum: DennisK, doncaparker and 28 guests
