It is currently Fri Sep 19, 2025 2:38 am
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2  Next
PostPosted: Wed Dec 10, 2008 11:23 am
First name: Chuck
Last Name: Hutchison
City: Houston
I've always wondered why the the widest part of the end graft points towards to the top of the guitar. This has always seemed backward to me. It really doesn't matter which way it is positioned does it? I know there are different shapes as some are just straight, some are curved, but why do the trapezoid shape end graft point the way it do? Any history behind it?
Of course the reason I ask is that I just cut it out wrong. So, with another mistake of not paying attention AGAIN......... [headinwall]
I'm just going to glue this puppy in. I swear, when I work on guitars I need to take that medicine for Attention Deficit Disorder, what's it called....Ritalin?
PostPosted: Wed Dec 10, 2008 11:36 am
Tradition...
PostPosted: Wed Dec 10, 2008 12:30 pm
If it seems backward to you with the big end up, then you did right!
I thought the same thing about the grain on my sides on a recent build. It curves up a little bit, toward the top on either side. Looking back, I would have done it the other way. Next time.
PostPosted: Wed Dec 10, 2008 12:38 pm
First name: Josh
Last Name: French
City: Houston
I prefer the wedge to narrow towards the soundboard, so I'm with you.
If I were you and I did it "wrong" - I'd leave it. I'd be pretty surprised if someone noticed and comments on it.
Instagram: @jfrenchluthier
PostPosted: Wed Dec 10, 2008 12:45 pm
I did only one guitar like this, and I like it. I would consider it a design feature…
Laurent Brondel
West Paris, Maine - USA
PostPosted: Wed Dec 10, 2008 12:49 pm
Chuck,
I’d say go for it!
If someone asks you about it, tell them you thought you would be bold, experimental and controversial and break with tradition. :roll:
:D
Wade
BTW nice one Laurent!
Wade
Nashua, NH
http://www.wadefx.com
PostPosted: Wed Dec 10, 2008 1:08 pm
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
I can't answer the why. I can't even recall which direction mine went in, now that I think about it. idunno
I would say that looking at that picture with the small end toward the soundboard it gives me the feeling of minimalizing the end to which the small portion points. I don't know...maybe it's like artistic perpective thing...you know when you draw a road or railroad tracks and the small end seems so far away. Just the feeling I get from that picture. I don't know if I would feel the same way with the guitar in my hands (especially that one, it's a beauty).
If it's tradition, then another tradition with guitars seems to be to try new things. Seeing as it's a design choice, and does not affect the tone, go for it. See if people like it. :D
Darrin
PostPosted: Wed Dec 10, 2008 1:20 pm
So when a drummer picks up your guitar they won't scratch up the back playing it with a pick.
PostPosted: Wed Dec 10, 2008 1:21 pm
They're suppose to be tapered?????
OK, here's my hypothesis: it's not for nothing that we call this the "butt wedge." You with me so far? It represents human butt cleavage. Now think about the kind of butt that has wider cleavage on the bottom. Lots of overweight, middle-age spread. On the other hand, how does the cleavage run on a cute, perky butt? See what I mean?
PostPosted: Wed Dec 10, 2008 1:30 pm
eek That was disturbing.
Jeremy Douglas
PostPosted: Wed Dec 10, 2008 2:05 pm
Last Name: Garrish
Wow.
Bob Garrish
PostPosted: Wed Dec 10, 2008 2:38 pm
When I use a large secondary or ortimental wood wedge in the back seam of a back (3 piece back) I always place the large end of the wedge towards the tail. and match that width with a wedge end graft tapering towards the top. the the design looks planed. if you place an end graft wedge reversed on a guitar without a feature that ties the wide part in some way to the back then most will see it as a mistake simply because the artistic conseption wants the width at the top. it on the other hand you have somthing that ties the width to the back the eye sees it as pland progression and it makes sense to the minds eye
PostPosted: Wed Dec 10, 2008 2:52 pm
when building a guitar, I always ask my students about guitars they have at home .. what is the tail wedge made from ?? most have no idea .. they never look ... most people, except makers, dont know, and dont even care. I follow the martin style of top wide, bottom narrow ...... anything else is the anti-Martin. :twisted:
PostPosted: Wed Dec 10, 2008 3:02 pm
I've always thought it was because the back center joint is usually more visible than the one on the top. You sort of have to line the graft up with the back joint, particularly if it's got an inlaid center stripe. If the top seam doesn't line up exactly it's not as visible, but making the graft wider toward the top makes it even less so. With the angled sides you can even tilt the end graft a tiny bit to make the center seams look more aligned. With a parallel sides end graft, such as is normal on classical guitars, you can't get away with as much.
PostPosted: Wed Dec 10, 2008 3:05 pm
Mitred or not?
How does the G string sound?
Laurent Brondel
PostPosted: Wed Dec 10, 2008 3:17 pm
Indeed.
PostPosted: Wed Dec 10, 2008 4:44 pm
First name: Chuck
City: Houston
LOL......only you Howard would think of something like this.
If that's the case, I'm drilling two holes for my end peg.
PostPosted: Wed Dec 10, 2008 4:46 pm
That could cut the other way: since the back alignment is more critical, make it harder to tell if it's off by putting the wide end down there. On the other hand, if you know you have it right, flaunt it.
PostPosted: Wed Dec 10, 2008 4:47 pm
Cause it looks better. (IMHO).
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Wed Dec 10, 2008 5:27 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I`m with Howard.I`d rather look at a cute perky butt.
James :)
James W Bolan
Nashville Tennessee
PostPosted: Wed Dec 10, 2008 5:29 pm
Filippo Morelli wrote:
Laurent,
Looks like Mahogany B&S ... photo saturated so it looks redish ... or?
Filippo
Bloodwood
Laurent Brondel
PostPosted: Wed Dec 10, 2008 5:54 pm
I cannot believe the turn this thread has taken , next we will be talking about sniffing wood through the sound holes ! unbelievable,, where is that moderator anyways ? Jody
PostPosted: Wed Dec 10, 2008 9:36 pm
Doesn't everybody sniff at the soundhole?
PostPosted: Wed Dec 10, 2008 10:45 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I do not know the answer... but my first attempt at building had me installing the butt wedge small end towards the top. It was the straw that broke the camel's back. I gave up on that build. It just did not look right to me. I keep that body around to remind me of all the mistakes I made. It is very ugly. And that dang backward butt edge! Sorry Laurent, I just do not like that angle. But the guitar itself is gorgeous!
Users browsing this forum: Bing [Bot] and 19 guests
