It is currently Fri Sep 19, 2025 4:09 pm
 Post subject: She is done
PostPosted: Sat Jan 03, 2009 10:21 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I polished the finish and glued on the bridge. I used a router to route off the finish then cleaned it off with sandpaper and chisel and razor blade while taping up other areas to protect the finish. I did it kinda fast and the finish is still a little soft so I did leave some imprints in the finish with the tape but you'd have to be really close in the right light to see it. I also routed a ledge in the bridge itself to allow the bridge to sit a little higher over the finish resulting in a clean appearance. I drilled two holes beforehand so I can glue up the bridge without fear of the bridge moving while gluing (would be a real nightmare!)
Next I will install tuner and nut then string it up and hopefully it will sound good... This guitar is going to be delivered to Afghanistan by a missionary team... I hope the Taliban doesn't harass them for no reason.
Typhoon Guitars
 Post subject: Re: She is done
PostPosted: Sat Jan 03, 2009 10:23 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Wow Tai,
It just seemed like yesterday your were showing pictures of it on your bed. You got it finished Fast.
Great job.
PostPosted: Sun Jan 04, 2009 7:44 am
Very nice Tai Fu - congratulations! [:Y:] [clap] [clap] [clap] [clap] [clap] [clap]
PostPosted: Sun Jan 04, 2009 10:58 am
Looks great! Hopefully it survives the trip.
Users browsing this forum: Geocoucou79 and 49 guests
