It is currently Fri Aug 08, 2025 1:22 pm
PostPosted: Mon Jan 05, 2009 11:14 pm
I have a German style bronze perfling cutter, but the 2 blades are center sharpened, not single bevel, and I don't have a grinder, so I was thinking just replace with Ibex blades. Does anyone know the width and if they are single bevel? Thanks
PostPosted: Tue Jan 06, 2009 9:11 am
Unless someone's been purfling an aluminum-bodied instrument, the cutters shouldn't be too dull. Perhaps you could hand-grind, either with sharpening stones you already own, or with sandpaper, or with a belt sander? Just try to take off the bare minumum, while following the original profile as carefully as possible. Did you test the blade to see if a file will cut it? Probably too hard, but you never know.
Dan
Dan
http://www.acme-archtops.com
PostPosted: Tue Jan 06, 2009 12:28 pm
Country: Romania
You can buy separate blade from LMI. They are good steel (I think they say they are made by Hock), and cheap. Dimensions are 33 x 5 x 1.4 mm - I hope they fit. One face flat, the other 2 bevels. They will work better if you sharpen and hone them once in a while.
Build log
PostPosted: Tue Jan 06, 2009 3:00 pm
I would have to grind off like 5/16 of bevel to get it level, with 100 grit or something.
Alexandrew, is the "5" -5 mm wide? Length and thickness don't matter too much.
PostPosted: Tue Jan 06, 2009 3:03 pm
Country: Romania
Yes 5mm
Build log
Users browsing this forum: DennisK and 37 guests
